Old 02-10-2012, 06:05 AM
klyg klyg is offline
Default Eucon with v-control pro ipad2 no vu levels showing !
Mc-mix / contol + V-Control pro with ipad2 is your best friends with PT ! (or other daw).
Too bad Eucon enabled in PT cannot show vu levels in v-control in ipad2 !
Please AVID do something !
Cause NeyRinck says it's a hui poblem with PT !
Who is right ?
AVID / NeyRinck ?
None of them ?
Old 02-10-2012, 06:07 AM
Brandonx1 Brandonx1 is offline
Default Re: Eucon with v-control pro ipad2 no vu levels showing !
Avid will never update hui protocol. Hui hasnt been supported for years.
Old 02-11-2012, 08:20 PM
tonepad tonepad is offline
Well... you can try the V window and see the metering in the edit or mix window there, but that whole thing is a bit laggy. Neyrinck did inform me that it is a PT/Eucon/HUI bug. The only other option is to disable (uncheck) the Eucon option in peripherals which releases the metering to the V-con main fader window. Depending on if that works for you or not it's an option/workaround. I use my V-con as a remote record controller so disabling Eucon when I need the V-con for that is not a deal breaker, but I could certainly imagine other scenarios where that may suck.
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 02-11-2012, 10:44 PM
Thks ! V-windows sure is great, although a bit lag, but really useful !
Cheers !
Old 02-11-2012, 10:45 PM
Really, NeyRinck keeps telling me to ask AVID for an update !
Sadly if hui will ever be updated in PT !
Cheers !
Old 02-18-2012, 10:17 AM
pneyrinck's Avatar
pneyrinck pneyrinck is offline
Neyrinck
This issue is not specific to HUI protocol. Pro Tools does not send metering to any secondary MIDI controllers, including Command 8, and my understanding is that it is a bug. If you haven't already, you can go to http://protools.ideascale.com/, search for "Enable Metering In Second Controller" and vote to get Avid to fix this.
Old 02-18-2012, 11:39 PM
Voted months ago, still waiting for a solution....
Cheers !
Cheers !
Old 07-13-2013, 04:10 AM
Cheers !
Still no Solution ? Is EUCON 3.0 going to solve this "v-control" issue ?
Cheers !
Old 07-13-2013, 11:53 AM
It's not a bug. That is the way it works. When another controller and HUI is in use, PT doesn't send HUI meter info. Just a limitation. Probably intentionally limit HUI. At least Avid brought HUI to PT11 and 64 bit.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 04-22-2015, 09:04 PM
jhumor jhumor is offline
avid, so how about it? 4 years in the making, i think wit hthe s3 and Pro Tools Control app this needs to work
Eucon, Artist Control and mouse. vinnyburns Artist Series 6 04-16-2014 06:43 PM
Eucon 3 problems - Mix and Control DrFord Artist Series 5 03-23-2014 08:57 AM
PC EuCon adapter not showing in Cubase 5.5.2 johngar Artist Series 11 04-10-2011 06:41 AM
not getting levels showing for bass...??? chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-08-2005 07:00 AM
levels not showing on pro tools 5.1.1 ronoc Pro Tools TDM Systems (Mac) 3 11-10-2005 08:54 AM
