Video solution for PT 7.4 and pci-x G5
Hey,
Anyone know of a good third party video capture card for a G5 pci-x system, or a reliable workaround with a graphics card? I'm running two systems right now with Aurora Fuse-X cards, but that company ceased to exist a while back and I'll be damned if I can find one of those cards anywhere (I actually just got burned on Ebay when I picked an old Fuse that doesn't fit - not enough coffee that morning, should have realized it was too good to be true). I've tried Canopus before, but due to the latency issue when you scrub and loss of frame accuracy, it's not an option. Anyone got suggestions for another card? The only other thing I can think of would be to run a dual monitor system off the graphics card, but I'm not sure how much that taxes the system resources. Any advice would be greatly appreciated. -- Dual 2.5 G5, 4 gigs ram, PT 7.4, HD2, OSX 10.4.11 |
Re: Video solution for PT 7.4 and pci-x G5
I just had to ditch my aurora card as well. Other than having good results with mojos, using the 2nd video monitor plugged into a television or projection with a dvi or hdmi input is a fantastic quick, easy, cheap, high quality solution. it is not bad on the system at all as long as you are using the normal video formats (dv or mpeg2)
Doug |
HD3|Accel Video Solution | stangroom | Pro Tools TDM Systems (Mac) | 3 | 01-10-2013 08:46 AM |
Video out - what's the most inexpensive solution | SoundPeopleDK | Pro Tools TDM Systems (Mac) | 1 | 01-20-2008 01:38 AM |
HD Video Solution | jeremiahjobe | Pro Tools TDM Systems (Win) | 3 | 10-17-2007 04:30 AM |
A new video solution | filmixer | Post - Surround - Video | 2 | 10-17-2004 02:42 AM |
Video solution? | Przemek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-04-2003 08:24 PM |
