Old 07-23-2010, 07:19 AM
Shanti Monkey Shanti Monkey is offline
Default 8.0.4 MIDI note duration change when editing
Hi !
When I am duplicating midi regions , after dulicating 8 region ,
there accour a delay on midi note and region
Pro Tools put the duplicated midi region 1 sample before it needs from grid.
so midi note is plaing twice at start point when looping
session sample rate 44,1kHz
thx in advanced.....for ideas
Old 07-23-2010, 12:37 PM
Default Re: 8.0.4 MIDI note duration change when editing
Use 'Region Looping' instead of Duplicate.
Aaron Mulqueen - 001 HD Native
Old 07-24-2010, 03:50 AM
thx for idea, yes i ve tried that but same problem.....
Now i made a new project with just one sturcture generating kick with midi ,
now no problem, so i can think about when more structure and boom and xpand
in the session, then somethink crashing and this midi problem came.
If problem came again i will try versions from 8.0 to 8.0.4 , and will see...
no other option.
(m box 2, dell latitude D 820 note book , external usb disk drive, 2 gb of ram )
thx.....
Old 07-24-2010, 03:54 AM
This problem caming after changing the default main tempo........
Old 07-24-2010, 03:06 PM
Is your computer compatible?
Old 07-26-2010, 02:31 AM
Hi Filo!
Yes full compatible intell Dell.
But I ve have solve the problem, this is a bug.
when i put the main counter to display samples or ms.
PT make this midi error when duplicating - 1 sample delay at region bounderies.
When i put the main counter to display bar and beats the duplicating works fine crazy but finded out ..
Old 07-27-2010, 02:56 AM
One way works without midi error.
Need to use the main midi edit on tracks notes view,
if i use midi editor window or built in editor for edit window , every midi note goes away from original time. And duaration when duplicating....
Dell Latitude D 820 notebook. (intel inside)
2,3 core 2 duo cpu
2 gb of ram
PT 8.0.4
m box 2
How do u extend Midi note duration in PT9? Metallicamasta Pro Tools 9 5 06-23-2011 10:01 AM
PT8 Score Editor - change note duration sladlow Pro Tools M-Powered (Mac) 15 08-16-2010 06:31 PM
Changing the midi note duration rbon MIDI 5 05-13-2008 04:11 AM
Changing MIDI Note Duration - Need Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-20-2007 10:47 AM
Change tempo without adjusting midi note duration Janiak Tips & Tricks 6 09-03-2004 03:34 PM
