Old 02-25-2009, 05:04 PM
crizdee's Avatar
crizdee crizdee is offline
Default Comments box in mix window SNAFU
Entering text into the comments box in the mix window is all mental since cs2!
http://www.youtube.com/watch?v=J4MAmVegrro
confirm/deny people
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-25-2009, 05:30 PM
A1's Avatar
A1 A1 is offline
Default Re: Comments box in mix window SNAFU
Works just fine here Chris.
Did you trash preferences etc. and Repair Disk Permissions after installing?
Old 02-25-2009, 05:38 PM
KingFish KingFish is offline
Hmm.. yeah - wow, thats strange - Not happening here.
Could it be "Different settings" on a Dual Display setup? I'm sure you've troubleshot the "Normal Stuff" - Hmmm weird one.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 02-26-2009, 07:32 AM
rstreber rstreber is offline
Yup, I'm getting the same thing here (sorry for starting a new redundant thread elsewhere...) Just repaired permissions and trashed prefs, and the strangest thing happened. The first time I typed something in a comment box, it worked fine. After that, it's whacky again. So weird! Incidentally, this is happening for me in the edit window as well as in the mix. Same thing too - first time I enter text in a comment box in the mix window, it's fine. Second and all subsequent times, it's screwed up.
BTW, i'm have dual displays here, don't know if that makes a difference.
Old 02-26-2009, 10:15 AM
DigiTechSupt's Avatar
Thanks for the report - we'll get this looked at asap.
Avid Audio Tech Support
Support FAQ
Old 02-27-2009, 08:49 AM
I did a location gig last night with my Magma/HD1/MacBook Pro system, and the comments boxes worked fine on that setup running 8.0cs2. So it's something with the MacPro / dual display I guess. Strange.
Old 02-27-2009, 09:10 AM
It might even be more "Narrow" then that. I'm on a MacPro 8 Core Harpertown, Dual Display, with no problems.
you guys should list your Spec's, especially Vid Cards, and Displays.
David
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
Old 02-27-2009, 10:39 AM
crizdee's Avatar
Thats the exact computer i have and with dual displays.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-27-2009, 12:56 PM
Same here, 8-core harpertown (2.8ghz), dual displays, ATI Radeon HD 2600xt graphics card, 10gb ram. I just bought this machine a month ago.
Old 03-04-2009, 02:33 AM
mhmh mhmh is offline
Same problem on my G5.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
> Comments Window unreadable will editing Howardk Pro Tools TDM Systems (Mac) 13 02-01-2014 02:41 PM
"Comments" window problem..Intermittent Roger Stauss Pro Tools HDX & HD Native Systems (Mac) 6 01-20-2013 03:51 PM
PT8 Mix window / Track comments bug ? stevegalante Pro Tools TDM Systems (Mac) 4 11-20-2010 12:28 AM
Larger Comments in Mix Window finkbmx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-21-2008 06:17 PM
Comments window on tracks barismanco123 Tips & Tricks 6 10-14-2008 11:05 AM
