Old 06-18-2007, 07:56 AM
JCWarrior JCWarrior is offline
Default Changing MIDI Note Duration - Need Help Please
How do I change the duration of a midi note? For example, say I want to change a group of midi notes that have different durations to all have the same approximate duration of a stacato note played as a 16th note at 200 BPM.
I've attempted to use the "Midi Operations/Change Duration" command with no luck.
Thanks.
Macbook Pro 2.16Ghz, 4 GB RAM, OS X 10.6.8,
1-Maxtor 200G & 1-OWC 80G External Firewire Drive. - Pro Tools 9.0.3
Old 06-18-2007, 09:35 AM
DigiTechSupt's Avatar
Default Re: Changing MIDI Note Duration - Need Help Please
Can you give the exact step by step you're using? I just tested this and the 'change duration' works fine on my system.
Avid Audio Tech Support
Support FAQ
Old 06-18-2007, 09:54 AM
Scott Church Scott Church is offline
Hi Jeff,
What are the steps you are trying, as the Change Duration command in MIDI Operations seems to be working properly here. This is what I am doing:
1. Make a selection on a MIDI Track set to Notes view of the Notes I want to change the duration of with the Selector or Grabber tool.
2. Event > MIDI Operations > Change Duration
3. Choose the "Set All to" radio button and enter a value in the text field - 2 beats for example.
4. Click Apply
Result: The duration of all selected notes is changed to 2 beats. Is that what you are looking to do?
Cheers,
Scott
Scott Church
Old 06-18-2007, 10:50 AM
This looks like what I'm trying to do. I'm not at my system now.
You set it for 2 beats (half note at 4/4 time). How would I set it for 1/16th note?
Old 06-18-2007, 04:44 PM
Hi Jeff,
So the first numeric field is for beats (so yes, in 4/4 putting a 2 there will mean a half note). The second numeric field is ticks (there are 960 of those per quarter note), so an eighth note would be 480 and a sixteenth note would be 240. So, just leave a 0 in the first field and 240 in the second field and you can set all the selected notes to be a sixteenth note.
Cheers,
Scott
Scott Church
Old 06-19-2007, 08:40 AM
Worked like a charm! Thank you!
Old 06-20-2007, 10:47 AM
You are welcome Jeff,
Happy to help
Cheers,
Scott
Scott Church
Custom Note Duration 10willy Windows 1 09-21-2012 01:54 PM
How do u extend Midi note duration in PT9? Metallicamasta Pro Tools 9 5 06-23-2011 10:01 AM
8.0.4 MIDI note duration change when editing Shanti Monkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-27-2010 02:56 AM
Changing the midi note duration rbon MIDI 5 05-13-2008 04:11 AM
Change tempo without adjusting midi note duration Janiak Tips & Tricks 6 09-03-2004 03:34 PM
