Old 05-25-2006, 04:57 PM
thebigshow thebigshow is offline
Default I have a problem...and I hope somebody has a fix
Ok, so heres the deal...
I work at a studio...one room is running Windows with an HD3...and the other is running Mac....I have 6.9.1 on the windows machine...and 6.7 on the mac....
Here's the problem...Both rooms record to Firewire drives....BUT....I want the Mac to be able to write data to the windows formatted firewire drives....So I don't have to keep transferring back and forth and back and forth between the mac and pc drives....since I use both rooms on a regular basis...
Can somebody help??? I heard there was an OSX update or something that made this possible...I have been out of the mac world for quite some time(used to have 3)....So any help is very much appreciated....
thx
brian
Old 05-25-2006, 05:16 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: I have a problem...and I hope somebody has a fix
Format to fat 32 and both mac and pc will read that.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 05-25-2006, 05:20 PM
frenchman frenchman is offline
no fix that I know of...
But look at this way, by having two drives, one formatted by Mac and the other by windows, you have a good backup scheme !
Every time you finish working on your session, on one system, before closing down, you copy it on the other disk. Only thing is you will need macdrive to mount your Mac volume on windows...
Maybe using file synchronizing software you can even only copy the files that have changed...
Mark Haliday
Engineer, Producer
Old 05-25-2006, 05:22 PM
FAT32 on mac will only be a transfer volume in Pro tools I believe ...
Mark Haliday
Engineer, Producer
Old 05-25-2006, 06:08 PM
jiggy_bau jiggy_bau is offline
You might also consider networking the two machines. Then you won't need to worry about the disk format. Just share your firewire disk from either your Mac or your PC, and you'll be able to access it on the network (make sure you give write permissions to network users). I'm not sure if Pro Tools will allow you to use such a volume as a playback or record volume. But even if it doesn't, I think you might be able to force it to. I remember having some projects on my system volume, and PT wouldn't open them, because they were on a transfer volume, so I had to manually set the volume preference from T to R.
If you find this at all interesting, I'll be happy to explain this in more detail.
Paul
Kids, don't try this on a Mac [img]/images/graemlins/grin.gif[/img]
I hope to solve my problem alBady Windows 1 10-21-2012 02:36 PM
Simple S/PDIF problem I hope Chas Young 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2010 09:45 AM
Hello, I hope someone can help me vastnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-09-2008 07:36 AM
Chipset problem? I hope not shatteredatom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-26-2005 10:57 AM
problem with latency on playback(I hope that is the right word) baz h Digidesign Hardware & Software 1 12-26-2001 02:16 PM
