Old 05-15-2019, 06:19 AM
garderobamusic garderobamusic is offline
Default Playback stops when editing in playlist view
Hello, I've been having glitches in playback (momentarily stops) while editing (X-fades, trimming clips) in playlist view. It started in 2018.12 and continues in 2019.5.
I'm on Mojave 10.14.4, MBP 2018, 32GB RAM...
I haven't found any other post about it.
Dear, fellow PT users, any ideas?
Would be very grateful...
Best
Piotr
Old 05-15-2019, 11:48 AM
daeron80 daeron80 is offline
Default Re: Playback stops when editing in playlist view
Same on Win10. Thought it especially odd since one of 2019.5's big plusses is supposed to be transport NOT stopping when you make changes. Used to be able to slide clips in a playlist without a hitch.
David J. Finnamore
Nyquist was right.
PT 2019.10 Ultimate | Omni | macOS Sierra
PT 2019.10 | Saffire Pro 40 | Win10
Old 05-21-2019, 11:07 PM
So I updated to Mojave 10.14.5, reinstalled 2019.5 and no change in the behaviour.
No one else is having the same issue?
Is there any recommendation anyone could think of?
I'd really appreciate your feedback, guys!
Best
Piotr
Old 05-21-2019, 11:34 PM
bolooki bolooki is offline
Best
Piotr
does it do this on 2019.7 too?
Old 05-26-2019, 12:45 PM
You mean 2018.7? Not available anymore.
Anyway, made some critical system update for MacBook Pro 2018 and will see if this changes anything...
Working in playlist view is impossible!
Regards
Piotr
Old 05-28-2019, 07:48 AM
Pretty sure it's a bug, because I can do all the other things that used to cause a hitch in playback. I can create and move tracks, add and remove plugins, and so on, with continuous playback. It's only when doing something to playlists that it hiccups.
David J. Finnamore
Nyquist was right.
Old 05-28-2019, 11:28 AM
seanmccoy seanmccoy is offline
I've seen this behavior off and on going back through several updates, probably even as far back as PT11. Problem is it doesn't show up in every project, and I've never taken the time to pull plugins to see if there's some connection there. I just ran into this in a project yesterday in 2019.5, but not on the next project. It's really annoying, but as you notice it hasn't gotten much attention.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2019.12, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.8, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU LP32, Pro Tools 2019.10
BUG: Playback glitch while editing in playlist view. reichman Post - Surround - Video 3 06-11-2019 07:41 AM
Bug: audio glitches editing stereo tracks in playlist view. b1daly Pro Tools 2018 3 04-10-2018 06:51 AM
Trying to view playback engine stops Pro Tools First JayM Pro Tools | First Discussion 2 11-09-2017 12:10 AM
PT hangs on transport stop when editing a track with many playlists in playlist view bolooki Pro Tools 12 4 01-17-2017 02:15 PM
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 12:43 PM
