Old 12-13-2001, 11:22 AM
songman songman is offline
Default volume automation
Hi all,
Since upgrading to 5.1.1 and making my 1622 the main interface with 882 as second, I am regularly encountering that volume-automation is not working. All I can do to get it working again is shut down and start up the interfaces again. Simply shutting down PT or even rebooting the Mac does not help. Any ideas very welcome.
Cheers to all, Bob.
PS I run a MIx cube in a 7 slot expansion chassis with a G4 500 DP. No problems at all with 5.1 and 882 as main and 1622 as second in the past.
Old 12-13-2001, 09:16 PM
Shawn Simpson Shawn Simpson is offline
Default Re: volume automation
Hi Bob,
What is it about your automation that isn't working? Do you mean that the faders are not moving? Or are you not hearing the changes? If it's the latter, do you hear a difference when you manually change the level of a fader? Have you tried making the 882 your main interface again and seeing if that fixed the problem(though I can't see why it would)? A little more information would be helpful.
Old 12-15-2001, 08:56 AM
DigiDawg DigiDawg is offline
Bob,
Gotta hunch here its the dual processor bug on the 500. I've got one and any time we used to try to write fader automation the machine locked up or gave dae errors.
The only solution of which I'm aware is to go to your extensions folder and move the "multi-processing" extension into the unused extensions folder and reboot. (I'm not on that computer right now, so I might have the name of the extension mangled a bit, but the extension is either "multi-proceesor" or "multi-processing")
This is the same extension that gives a ton of dae errors on the 500 DP's. There's a thread here on the DUC's tech page that deals with this too - that's where I found this fix. Thing purrs like a kitten now.
Good Luck,
DigiDawg
Volume Automation.. thierryhenry Pro Tools 10 5 01-05-2013 12:46 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
FCP, OMF & volume automation idris Post - Surround - Video 9 09-03-2010 08:06 AM
volume automation cpt Pro Tools TDM Systems (Mac) 9 02-12-2010 01:30 PM
Volume Automation Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-10-2003 02:23 PM
