SETTING UP YOUR SPIDF
OK GUYS I KNOW THIS IS REAL EASY BUT I CANT GET IT.
HOW DO YOU CONFIGURE THE MBOX 1 FOR SPIDF RECORDING AND HOW DO YOU CONFIGURE YOUR HARDWARE. ANY SOLUTIONS ARE NEED ASAP, AND MUST BE IGNORANT BUT HOW IS THE INSERT I/O USED ON THE M BOX 1 THANX IN ADVANCE |
Re: SETTING UP YOUR SPIDF
Using your 75-ohm coaxial cables connect MIDI device Out to Mbox In, Mbox Out to MIDI device In. Then go, Pro Tools Menus>Hardware Setup, in the Peripherals box select Mbox and then assign the Clock Source>S/PDIF, set the Sample Rate to either 44.1 or 48 Samples depending on your MIDI devices capabilities, most MIDI devices support either... or... In the Mix window assign the Input to Analog 1-2, S/PDIF will not show up. filosofem
Aaron Mulqueen - 001 HD Native |
SPIDF Problems | Rodge A | Pro Tools M-Powered (Mac) | 6 | 07-07-2007 03:59 PM |
SPIDF CONVERTER? | volume9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-27-2005 09:56 AM |
TRITON SPIDF to 002, question... | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-21-2005 12:34 PM |
001 Spidf (0pt) NOT working!!? | studiouniverse26 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-08-2003 10:49 PM |
spidf on digi 001 | jkofoed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-12-2002 05:58 PM |
