auto backup question
I am trying to figure out how to make auto backup where I want it to be done...
1) In PREFERENCES > Operation : I can see that auto backup is set to be done every 5 minutes (10 last updates). But I do not see where it is done nore how I can change this. Unless the section below (User Library) is exactly this ? - In which case, this means (now) that by default it is backed up the last place I want it, that is on the Mac HD drive ??... (Therefore, I would change it - one, for better safety, two - to avoid getting that SSD drive crowded in no time. 2) I also read articles saying I could use (session by session I guess) the function "Save Copy In". However, the issue in that case is I do not see any way to see or change location of that copy... In both cases, I would assume it would backup everything - audio, midi files, etc. ? Also, How about using a 1TB DropBox for and additional (3rd, external) backup ? Thanks, Rob
Rob ____________________ |
Re: auto backup question
Automatic backups are always done to the session folder.
Save Copy In allows you to choose what you want to save a copy of. For .ptx files, sure. For entire sessions, you are going to need a massive amount of bandwidth to make saving an entire session to DropBox practical.
Thanks for these explanations, indeed yes I believe the Copy option is a good way.
However, to have something external - done manually, not in real time (saving projects...), I am still thinking of DropBox. Bandwidth is not a concern as I do not expect backup while working on a project. On DropBox site, I see this : Right now, Dropbox will only sync the files in your Dropbox folder. However, there is a way to sync a folder using Dropbox and still access it from outside your Dropbox folder. For example, say you want to use Dropbox to backup a folder and make it accessible from all of your computers. However, you still want to be able to access it from its current location. In this instance, you can move the folder you want Dropbox to sync into your Dropbox folder and set up a shortcut (Windows), alias (Mac OS X), or link (Linux) to access it from its former location. Not sure I can really do it and work from the folder if it is only an alias, can I ?? How safe it is ? Anyone does that ? Only solution appears to be : copy manually the ProTools project folder to the DropBox folder (so it now takes twice the space on the computer....), and let the copy sync to DropBox... Rob
Rob ____________________ Last edited by JFreak; 01-25-2015 at 10:33 PM. Reason: fixed color tag |
https://www.backblaze.com/?gclid=CKC...FaFr7AodSFkAfw
Might want to look at something like this over Dropbox. Gonna be way cheaper. |
One of my coworkers uses Backblaze for his personal backups. He thinks it is great.
As for the syncing of a folder that is not within the DropBox folder, you are best served with a symbolic link. There are two types of symbolic links. One is called a hard link. The other is just called a symbolic link. You should not need a hard link for what you want to do.
Thanks for these info and tips about DropBox.
About BackBlaze I might try this. However, I'm reading much more complaints than pros on the service - fantastic until one tries to recover something... Not sure... But it would indeed looks very interesting - although I do not aim to backup 5 TBs over a month at 10 GB per day (it's possible to set filters but... how many with 6HDDs and hundreds of folders on this machine... But interesting to know other options - very appreciated. Thanks, Rob
9.0.2 auto backup bug... | mykhal c | Windows | 16 | 04-20-2011 10:37 PM |
Auto Backup not doing anything | Johanna Herr | Pro Tools TDM Systems (Mac) | 2 | 04-11-2007 03:47 PM |
Auto backup error??? | protuser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-13-2006 12:54 PM |
Auto Backup question | Don Geppert | Pro Tools TDM Systems (Mac) | 1 | 10-29-2006 01:10 PM |
Auto Backup feature | Kenny Gioia | Tips & Tricks | 4 | 05-02-2003 08:49 AM |
