New Eleven Rack...can't install Pro Tools 8
I just got an Eleven rack that came with Pro Tools 8. Everything was working fine until I had to do a clean install of Windows 7. Now the disc installer is not responding.
After I put the disc in and click Setup, a blank "Welcome to Pro Tools LE" window pops up. There is no option available to install. I even tried an external DVD drive in case in was a drive error, but to no avail. I don't understand why it worked perfectly the first time, but now when I try to reinstall I get nothing. BTW, I was going from Windows 7 64-bit to Windows 7 64-bit. Just needed a clean install of the same OS due to some unrelated problems. Any advice? |
Re: New Eleven Rack...can't install Pro Tools 8
No one? Really??
You could try registering on the Avid product registration page and see if the PT8 full installer appears in your account. Besides that you could order replacement discs.
heres what i did when my dvd drive failed on my main rig during the install.
go to another computer, create an ISO of the disc with PowerISO (free software). put it on a usb drive (at least 8 gb), transfer it to the destination rig, and mount the image file (the ISO file). Worked like a charm and installed MUCH faster than off a slow dvd. Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
Since you are on Windows 7 64 bit, you should be using no less than Pro Tools 8.0.3 cs2.
Register everything with Avid, create your Avid account, and you should get a Download for Pro Tools 8.0.3 Full installer placed in your Avid account. Download it, install it, then I would update to PT 8.0.4cs2
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Maybe it was, but PowerISO is no longer free. The trial version will only work with up to 300 M. Any other suggestions?
Edit: how do we order replacement disks? Last edited by StrangeDays; 01-21-2011 at 03:34 PM. Reason: added questions |
Here is the replacement disk link.
http://shop.avid.com/store/product.d...24157342779680 But isn't it limited to downloaded versions? Will they still work with Digi DVD versions provided we still have the serial number? |
I had the same problem only I am using XP pro.It installed just so far then froze.
It turned out it didn't like Internet Explorer 8. I reverted to IE6 and it installed no problem. |
BTW, I restored to a backup I had just prior to the clean install and everything is working great again. |
I'm not sure that its applicable here but there have been instances were it was assumed that the installer was hung when in fact there was a dialog window waiting for a response behind the main installer window. You might try WIN+TAB-ing or ALT+TAB-ing through the windows to see if there another pop up window looking for your attention.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
How to install Eleven Rack to PTLE 8.05 | cruisemates | Eleven Rack | 18 | 11-12-2013 03:08 PM |
Eleven Rack Expansion Install Problem | danrussell185 | Eleven Rack | 12 | 12-21-2012 04:57 PM |
Pro Tools 8.0.1: install disc doesn't work (Eleven Rack) | Mister_Riff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-21-2011 08:20 AM |
Eleven Rack not recognized during install | mmurphyrichardson | Eleven Rack | 5 | 12-23-2010 07:11 PM |
Bought an Eleven Rack and Pro Tools won't install, help!!! | kgtele | Pro Tools TDM Systems (Mac) | 1 | 06-11-2010 01:33 AM |
