Old 09-14-2001, 02:28 PM
Terminal Terminal is offline
Default Phase problems when bussing
Ok, when I buss drums or other instruments to apply a 2 track compression (ren. comp) I am getting phase cancellation. I do try to phase reverse when it comes back to the console, but this doesn't work. Any suggestions on how to fix this?
Old 09-14-2001, 07:42 PM
Kenny Gioia Kenny Gioia is offline
Default Re: Phase problems when bussing
I'm assuming that what you're doing is returning the compression buss along with the original signal.
So either, this is a mistake and you shouldn't do that
or you prefer to mix the uncompressed drums with the compressed drums.
In the latter case you should send all the drums to two seperate busses. Then compress buss A with your Ren Comp and put the TimeAdjuster plugin on buss B and set it to equal the delay time of the Ren Comp.
That should do it
Old 09-14-2001, 08:23 PM
Thanks Produceher. I was going for a blend of the signals. I will try that suggestion and I am sure that will work. Thanks again!
problems bussing LIVE into PTHD 8 workhouse Pro Tools TDM Systems (Mac) 1 08-19-2010 11:44 PM
Protools bussing and latency or phase issues when doing.... broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2008 05:31 AM
Bussing to outboard phase issues Media Man Pro Tools TDM Systems (Mac) 4 02-23-2006 08:29 AM
How to fix phase problems? Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2002 02:04 AM
phase problems - please help onemanband Tips & Tricks 5 02-28-2001 09:12 AM
