#91
Re: Is Pro Tools behind the curve?
Even back then it was mostly ticking a box and recompiling, most of the work was dealing with random bugs. I bet they (in-house development a.k.a. alpha team) already have it working on ARM but sure it is still long way to be ready for beta testing. Beta testers do not have hardware yet.
#92
#93
Will see. Drivers is the biggest problem for sure, expect some stuff get left behind.
#94
Remember, driver development and PT development go different route. Avid may already have ARM hardware running their software with generic built-in output. PT itself is "easy", but drivers are low-level and need more time. Anything that is not supported now will not be working in ARM platform, pretty much given.
#95
Re-compiling code for a different processor is never easy. It will be a challenge. You can all but guarantee it will be much more than a straight recompile, and some code will need to be modified. So if anyone has been on the fence about switching to PC from Mac, this might be a good time to consider it. The first ARM version is likely to be a work in progress.
#96
You sound like some of the marketing people at places I worked, back in my software engineering days. "Nothing to it" they would be telling upper management and customers. Meanwhile the SE's have to work out the details. Some ports are easier than others, but I have to think going to a different processor will be a significant task for an app like PT, with all of its time critical code.
#97
Will the switch from Intel to ARM have any impact on RTL? Like, how does latency through ARM processors compare to x86?
#98
The CPU is not the issue there.
#99
Do you know that from technical expertise, or are you making an assumption? From the outside looking in it seems like there could have some impact. A different CPU will have different scheduling algorithms and require different drivers, which seems relevant. Of course it could be a positive impact, and latency might be better, depending on the drivers.
#100
RISC usually has less realtime problems
EQ Curve | spoons | Avid S1, S3, Dock and Control App | 6 | 01-10-2017 04:16 AM |
X-curve | mr.armadillo | Post - Surround - Video | 0 | 04-27-2014 04:32 AM |
Pro Tools Learning Curve | DJKeys | macOS | 14 | 07-19-2011 02:57 PM |
Learning Curve for Pro Tools from SX or Nuendo Use | musicmanz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-06-2005 04:17 AM |
How can I see my EQ curve? | uno1234 | Pro Tools TDM Systems (Mac) | 3 | 08-11-2005 02:15 PM |
