Re: Default EQ / HDX / Only Multi Mono? Why?
For anyone else, here is the process I found on another thread - --------- You use REQ 6 a lot. Say it's the DSP version of REQ. (it doesn't matter actually. this works for both DSP and Native Plugin lists) You want to put it on your kick drum track, say. So you click the insert track of your kick channel, scroll to DSP, to EQ then down to REQ. Now you want to use it on your snare track, BUT you're tired of scrolling through 100 eqs to get down to the REQ in your EQ menu every time you want to use it. Here is the solution: Click on the insert on the kick channel, scroll down to the REQ, hold command, then select it. Ok, so right away it seems like nothing happens. The plugin won't pop up on the track. But something magical did happen! Because now when you click on your insert, and scroll over to DSP, you'll find that the REQ plugin is waiting for you there ABOVE where the usual "eq" "dynamics" etc. lists are. Try it! you'll see what I'm talking about. This works for the Native list as well. And actually the lists are independent. So you can have your 'favorite' DSP plugins, and Native plugins. Also, a side note, the lists are also independent for stereo and mono tracks. So, you kind of have to build your favorites list for both. But once you start using a plugin a lot, you'll eventually just command click it and bam, it's in your list. I have been doing this for a while now and there seems to be no limit to it. I probably have something like 20 favorites in the DSP menu, about the same for the Native both mono and stereo. Hope this clears it up! Let me know when you have witnessed the magic for yourself. -----------
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
:) It works for the Audiosuite plugins list too!
It's going to be a huge timesaver for me. Thanks again!
Have Fabfilter released the fix for this?
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
Problem with this is its session dependent....would be nicer as a global pref.
It's a Global Preference for me and always has been.
But just 2 as global....when you do the CMD trick you can have 7-10 whatever number of plugs
Which is nice, 1 or 2 of each Type of plugs..... Buss Comps Channel comps Channel strips Delays Master EQ's Your not just limited to 2 of your fav's out of MANY
I found the answer - the most recent version 2.05 has the problem resolved. I updated today from 2.03 and Pro Q2 is no longer inserted as multi-mono on stereo tracks when selected as a default EQ :)
Can you have "center" as default view with multi mono plug in? | dgoodi22 | macOS | 4 | 02-08-2013 12:41 PM |
Viewing center by default on multi mono instances of 5.1? | cocamycola89 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 10-11-2012 02:19 AM |
Multi-channel vs Multi-mono plugs on 5.1 tracks | geitz | Post - Surround - Video | 0 | 06-08-2007 09:06 AM |
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-13-2002 11:08 AM |
Multi Mono vs Multi Channel Plugins...Just curious... | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-18-2002 09:46 PM |
