Re: Loop Record doesn't record
So I made a new track as Instrument (I recorded the Drums via the PT plugin "Boom").
For Instruments there are neither waveform nor playlist available from the Edit Track View. |
Instrument tracks are not for recording Audio. You are not going to make good progress stumbling around like this trying to get started with such a complex piece of software. It's normally better to start by following some Pro Tools tutorials covering what you are trying to do. Your Tube is a good place to find them. There are commercial courses as well, the Pro Tools 101 book, and ultimately the Pro Tools Reference Guide which is installed on your computer already and where you can read about what an Instrument tracks vs. Audio tracks.
I'd like to tell that I have solved the problem.
I don't have to tell all the pros around here that PT makes differences between Audio and Instrument (I finally learned last night). But on my opinion that's a really confusing way to manage records, especially because the way to do it on an "Audio-Track" is some kind of different (and really ALL tutorials I found obtain on how to record loop Audio-Tracks. Really funny, but that was the hardest point to figure out the whole mess). So to loop record Drums, you have to create an Instrument-Track, then activate midi merge, ONLY loop the "Play"-Button in the Transport-Window, activate "Wait on Note" in that same Window, then "Input Quantize" via Event-Input. Maybe you can also create a Click-Track – and then … have fun. |
Loop playback /record doesn't work. | IVcrane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-18-2016 01:43 PM |
Loop Record and Loop Playback will not engage? | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-28-2008 06:03 PM |
Master Record button doesn't record arm MIDI tracks? | Borg | ICON & C|24 | 1 | 10-29-2007 07:39 AM |
Loop Record Doesn't give me pulldowns | soundsurfr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-24-2006 12:09 PM |
