Bounce Question**
I'm about to hand in a mix for a record release. I have 888/24's. If I use an Apogee Trak2, will it actually effect the bounce and make it sound better. Need to know ASAP. Thanks in advance.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
Re: Bounce Question**
An external clock only effects things going in and out of the converters.. it doesn't help internal processing.
Rail
Thanks Rail, I had a feeling about that. So If I have used an Apogee in the recording process then it would make difference.
Yes.. instead of BTD, you may want to record your mix analog through the Apogee and compare it to your BTD tho'. Let your ears decide which you prefer.
Rail
Question about mp3 bounce down | bonzerboy | General Discussion | 2 | 11-12-2011 04:28 AM |
Bounce Question | bassbuddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-23-2008 12:20 PM |
Another Bounce Question | E-Buzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-22-2005 08:22 AM |
Bounce question??? | HR123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-07-2003 12:12 AM |
Bounce question | elliprelli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-06-2001 10:34 AM |
