Need help importing midi files
I have switched over from PC to Mac and am using PT MBox 6.0 I have tried to import old cakewalk sequences using both 1 & 0 file formats and each time I import the midi data into PT the file shows up fine with all the tempo markers, length of track correct etc. it's just that the data in the tracks shows up grayed out and doesn't play. When I record midi directly into PT the data shows up green and plays back. Am I doing something wrong? Any help would be apprecitated.
m.m. |
Re: Need help importing midi files
The notes will be greyed out until you assign the MIDI track to an MIDI output be it an internal routing to an RTAS synth or to an external module...When you're recording new tracks you have them assigned to some sound source to hear what your playing...right
That was the answer. Obviously I'm a new user. Thanks for the help.
m.m. |
Importing MIDI files | z17531 | macOS | 0 | 02-04-2011 12:30 PM |
Importing MIDI files into PT 7.4 LE help | Plexz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-31-2010 12:18 AM |
Importing midi files | spidey01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-26-2010 12:41 PM |
Importing midi files from mac to pc? | mix2much | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-28-2002 12:43 AM |
Help with Importing Midi Files into 001 | rj333 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-21-2001 12:18 AM |
