PT Free at 48k
I can't seem to get PT free to create a 48K session on my 266 wallstreet laptop. 48k is greyed out in the session setup window. Is it a limitation of the Mac? I've got a TDM rig and want to do some offline stuff. Anyone? [img]images/icons/confused.gif[/img]
Re: PT Free at 48k
In the Pro Tools Free FAQs:
http://answerbase.digidesign.com/detail.cfm?DID=4385 quote: As far as I know, the only Apple models that ever supported 48 k using Sound Manager were the Quadra 660 AV and 840 AV, which came out just before the PowerPC.
Administrator Avid Pro Audio Community |
Re: PT Free at 48k
I know this is WAY old - but, what version of sound manager were those computers using - can we use that same version and work away at 48k?
I've got 48k sessions that I'd like to edit in PT free until I can afford an mbox. |
Re: PT Free at 48k
not possible. sound manager is only capable of 44.1kHz.
mbox 4 u Quote:
Pro Tools & Logic Programmer, Engineer, Consulting, Education |
Re: PT Free at 48k
Offline editing is not editing on the real thing as far as i know. Why not just convert all the files to 44.1 Kz on the TDM. It will introduce errors and samplerate artifactsnb etc., but who cares, you are going to do all of the editing again anyway......
What's that? - That's the machine that goes "pling". Bastiaan |
Re: PT Free at 48k
Myself, I wasn't thinking or talking about offline in the sense that I was planing on editing a copy of a file, with a different sample rate, quality etc - and I doubt the orginal poster was either.
I can't see a time when anyone would want to edit something twice, the same way. Anyhow - my question was "if sound manager used to handle 48k - what was that version, I wanna try using it". Most of the USB devices available will handle 48K. Actually - Final Cut Pro handles 48K (via DV etc etc) so, where is the 44.1 limit there?? Digi, are you saying sound manager doesn't handle it, or you've stripped the code to give DAE errors if tried... Anyone else had any luck here?? I just wanna do a little editing on my iBook - I've got a TDM rig, but it's not the most portable thing to take with you... |
Re: PT Free at 48k
IM Sound 2.2 - About the Sound Input Manager: IM Sound 5.4 - About Sound Components: siSampleRate Get or set the sample rate to be produced by this device. The sample rate must be in the range 0 to 65535.65535 Hz. The sample rate is declared as a Fixed data type. In order to accommodate sample rates greater than 32 kHz, the most significant bit is not treated as a sign bit; instead, that bit is interpreted as having the value 32,768. The infoData parameter points to a buffer of type Fixed, which is the sample rate.
J.Y.Bernier Project mgr. SPECTRA Soft |
Re: PT Free at 48k
The Sound Manager handles 48k since the beginning. Please, take a look at http://www2.pescadoo.net/recorder.gif What you see is an application recording at 48k on a Roland UA-5. The Rate is not an app preset, nor a resource string. Is it the very value returned by theSound Manager Sound Input Device converted to string.
Re: PT Free at 48k
So without additional hardware, I'm pretty sure you would need to have a Quadra AV model in order to record in true 48 k sound just using a mac. I could be wrong, of course. [img]images/icons/smile.gif[/img]
Re: PT Free at 48k
Digiadmin - you're probably right.
What about using a Griffin iMic - does that unlock the "secret" 48khz?? According to their website they handle 48k. TIA. |
Noob question: Free vs. not free effects | tpann | AAX Plug-ins | 12 | 02-20-2013 02:59 PM |
PT10 Eleven Free & Structure Free | SteveBennett | macOS | 1 | 04-27-2012 06:37 AM |
Free or almost free GM plugin advice | imcivor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-22-2007 10:59 AM |
Where is the Free Download of Pro Tools Free? | iank | Digidesign Hardware & Software | 1 | 06-29-2001 03:08 PM |
free PT - free scratching audio | Melita | Digidesign Hardware & Software | 1 | 11-14-2000 03:09 PM |
