Anyone using Soundgrid Studio still?
Is anyone using Soundgrid Studio still with DiGiGrid interfaces?
Outside of a HDX system, it still seems the best way to track with plugins at a low latency. I'm curious to know everyone's experience and tips. I'm got a session coming up that I plan on using it with a personal monitor mixing system. https://youtu.be/Cd7n-pcjr90 Last edited by Josh Voyles; 02-05-2017 at 07:57 AM. |
Re: Anyone using Soundgrid Studio still?
Thanks for the reply.
I'm pretty familiar with the configuration, but my issue runs a little deeper. Everything operates ok despite the higher latency until you start overdubbing using pre roll. When you initiating recording with pre roll, the track you're recording starts playing back without delay compensation and then everything else is delayed. This presents series issues with time. I'll note, I copied the same session to Studio One and have not had this issue. (The latency compensation is much less too.) It seems to be isolated to Pro Tools and StudioRack integration. |
Btw...are you completely off Soundgrid period?
Given the recent changes in HD pricing, etc...HDX is looking for appealing these days. |
Yes - off SG since last spring.
So latency on SG - this should never be an issue in INPUT mode right? As far as latency through SG and PT this should be more about the buffer size than anything else. I used to measure at 96kHz something like StudioRack in INPUT mode = 1.2ms SR not in InputMode monitor through PT 96k/64buffer = 4.1ms So regardless of the delay comp value - when monitoring I never saw any of that show up in RTL (and it was like 3 or 4 thousand samples). Assuming one has an HD license - HDX card used close to $2K. Hard to see that as a barrier But HDX has its own pluses and minuses as this month I have to donate $400 for keeping my HD plan up to date!
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Latency on input mode is fine. The issue is only with the latency (or lack thereof) with pre recorded material on the track being overdubbed.
This is obviously only an issue using Soundgrid mode. With the plugins I'm using, there is zero latency in CPU mode minus DAW buffer, etc... |
Not sure I totally get it but haven't used SG since PT11 so this maybe a new PT12 issue with them... best of luck.
Here is the video showing the issue.
I've submitted it to Waves and it's being addressed. https://youtu.be/zilxPgHg3tQ |
More Soundgrid questions | Josh Voyles | AAX Plug-ins | 4 | 11-26-2015 09:42 AM |
FS: Waves Diamond SoundGrid/Waves SSL 4000 SoundGrid/Eventide Anthology II TDM/HEAT | neilvg | Buy & Sell | 6 | 09-29-2014 03:05 AM |
Waves SoundGrid system in Studio? | AudioElementsLLC | AAX Plug-ins | 5 | 08-27-2014 09:43 AM |
FS: Waves Studio Classics -(Soundgrid/TDM License: starting bid BELOW Native!!!) | L.O.N. | Buy & Sell | 0 | 08-20-2013 10:41 AM |
FS: Waves Studio Classics Collection Bundle - (Soundgrid/TDM License) | L.O.N. | Buy & Sell | 1 | 08-12-2013 10:23 AM |
