Old 05-03-2020, 12:07 PM
JoeM JoeM is offline
Default Best Way to Move Pro Tools Native HD System from Cheesegrater to New 2019 Mac Pro
Hi all,
I just purchased a 2019 Mac Pro, 12 Core, 96 GB RAM, 2 TB SSD for system and apps and 2 TB RAID 0 Accelsior SSD for my projects along with a PT upgrade form PT 11 to 2020 Ultimate. MY current PT system is a 4,1 Mac Pro running PT 11.3.2 with a Native HD card, Omni HD I/O, a UAD Quad PCIe card and plugs along with a load of other plugs and software.
I'd appreciate advice on the best way to transition my whole system over to the new Mac Pro. I have Carbon Copy Cloner and have read here in the past that some just clone their drives over to new machines and re-enter any passwords and logins that are needed. Is that still ok to do or is there a better way?
Also, Should I first download and install PT 2020 on the new Mac Pro and then install my HD Native card afterwards or install the card first before PT?
Any help and advice is greatly appreciated!
Thanks,
JoeM
Old 05-03-2020, 12:20 PM
Default Re: Best Way to Move Pro Tools Native HD System from Cheesegrater to New 2019 Mac Pro
My method would be to install everything fresh(don't load old stuff into a new computer). Then install Pro Tools and the HD driver. Then shut down, install the HDN card and reboot>test. I know installing everything is way more work than migrating, but its going to net you a much smoother system(my opinion).
Old 05-03-2020, 01:16 PM
So if I clean install, I imagine the order would be:
1. iLoc, PT and HD driver - test
2. HDN card - test
3. UAD Quad PCIe card and plugs
4. Installers for IK Multimedia, Toontrack, Waves, iZotope, Plugin Alliance, etc.
Would that be correct?
Old 05-04-2020, 07:49 AM
2. HDN card - test
I think your 1 & 2 could be done together, but yes, that's how I would do it(I would also save a drive image after each step)
Old 05-04-2020, 10:21 AM
I'm in the process of finishing up a project on the cheese grater so I planned to leave the card in till done but at least I can get started with installing PT 2020 on the new Mac. That's a great idea about creating a disk image after each step, thanks!
JoeM
PT 2023.12.1 Ultimate, 7,1 Mac Pro -12 Core, 96 GB RAM, OS 12.7.4 Monterey, 2 TB SSD system and apps, 2 TB Accelsior RAID 0 SSD projects / HD Native card with HD Omni, Eleven Rack, UAD Quad PCIe, UAD TB3 OCTO satellite, MOTU midi express 128 // Mac Pro 4,1 - 2 x 2.26 GHz Quad-Core Intel Xeon, 32 GB RAM, OS 10.10.5 Yosemite, PT 11.3.2
Old 05-04-2020, 12:35 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Congrats on your new BEAST! I literally spent the last couple of days doing the same thing. I went from a 12-core 5,1 to an 8-core 7,1. The performance already is over 50% more at least. I agree, do clean installs. Hopefully you have newer Waves versions otherwise you may run into installation issues. There are some "tricks" to allow installation on Catalina, though. Everything else will benefit from clean installs especially due to Catalina.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 05-04-2020, 05:03 PM
c-tone c-tone is offline
I believe that the PT installation notes specify that the HD card be installed before installing the software, but I don't think it makes a difference in the end. Read the PT software Installation instructions / notes pdf before installing either to make sure everything is done correctly.
www.clifnorrell.com
Old 05-04-2020, 06:43 PM
Thanks, likewise congrats on your new baby! They are pretty impressive Macs. I don’t have a lot of Waves plugs, just a couple of the Abbey Road plugs at V10 and the H Delay at V9. I can upgrade them for $51. which I guess I’ll need to do.
JoeM
Old 05-04-2020, 06:49 PM
Thanks, I thought that was how I originally did it when I first bought it but I read a number of posts here where guys where installing PT first and then added the card so I figured I’d try that since the card will be tied up in my cheesegrater for a week or so more. As of now PT itself is working fine. I read the Read me first and What’s new docs but didn’t read the install info. I’ll do so now.
JoeM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
HD Native Not Showing Up PT 2019.12.0 Win 10 SeparatistAudio Pro Tools HDX & HD Native Systems (Win) 6 01-19-2020 09:25 AM
FS : Avid HD Native PCIE card with Pro Tools Ultimate 2019.6 Perpetual License Marc Hudson Buy & Sell 0 10-28-2019 06:33 AM
Pro Tools 10 native on HD2 system rb99 Pro Tools HDX & HD Native Systems (Mac) 4 10-19-2013 09:45 AM
legacy PCI-based Pro Tools system to Pro Tools|HD Native card program cozy_man Pro Tools HDX & HD Native Systems (Mac) 8 10-28-2011 07:22 AM
