long time problem with "duplicate" keyboard shortcut
hey DUC, this is a huge newb question that ive held out in fears of getting flamed, but please bear with me..
Ive been using protools since v 7.1, and have always been stumped as to why that particular key command(command+D) has never worked for me( even then ). it would help me out editing a great deal. Ive made sure that command focus is turned on,and have" use all f1 f2 etc keys as standard function keys" checked. i have disabled my computer going to sleep, and disabled my quick corners. I have a first gen macbookpro and am running a digi002 with a 1TB WD external HD. whats even more odd about this is that if i use the drop down menu, the duplicate function works fine. doing it that way just wouldn't speed up my workflow. i know it sounds like a silly question, but any help figuring this out would be greatly appreciated. Thanx i neglected to mention that as of yesterday, i had another PT user come over with his mbox and macbook, and his command shortcut worked. mine seems to only copy to the clip board rather than duplicate forwards. its an odd anomaly. Last edited by Phototropic; 10-02-2009 at 02:25 PM. Reason: my writting apple+d rather than command+d seems to be confusing the issue |
Re: long time problem with "duplicate" keyboard shortcut
That's Command+D.
filosofem |
Apple+D = DOH!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
are they not the same key?the modifier works for everything else...
With respect, regarding PC, Ctrl isn't Start and Shift ain't Alt. The functionality of Modifiers modifies the normal action of any given keyboard.
Regards. filosofem |
This thread:
http://duc.digidesign.com/showthread.php?t=255337 Had a user with an inexplicable Command+Space problem... He solved it himself in the end, so read through, maybe it will help..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
According to my mac they are one and the same key.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
So you're saying musicalavtech that Apple+D duplicates?
filosofem |
Yes Filo, according to the mac shortcuts. Command (Apple) + D is for duplicate. What is the PC equivalent?
Shortcut for "Duplicate Backwards" ? | KingFish | Tips & Tricks | 12 | 07-17-2018 05:53 PM |
Midi Clips View Problem, option + "-" keyboard shortcut broken | kingtinker | Pro Tools 10 | 5 | 09-25-2016 01:47 PM |
Mac Keyboard shortcut for "Hide Pro Tools HD" does not work in 11 | The Recordist | Pro Tools 11 | 6 | 11-24-2013 02:35 PM |
Can we get a keyboard shortcut for "PROCESS" in an audiosuite plug-in??? | pshammond | Tips & Tricks | 0 | 09-24-2010 11:57 PM |
Keyboard shortcut to toggle "Play MIDI Notes When Editing" | Soul Finger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-17-2010 06:29 PM |
