How do I connect an external mic pre amp to the mbox 2?
Hi, Im thinking of buying a Focusrite Trackmaster pro channel strip today. Im wondering how would i connect the Focusrite to my Mbox2? Im using the Focusrite for the mic pre amp instead of the Mbox2. Also im wondering is the Focusrite Trackmaster Pro Channel Strip any good? Please help!!
Appreciate it.. -Dennis Heres the Specs. on the Focusrite and the link to the site.. http://www.guitarcenter.com/shop/pro..._sku=103145827 Focusrite TrakMaster Pro Channel Strip Features: Vocal and instrument processing channel for recording and live use FET-based mic pre Phantom power Line and instrumental inputs Fixed high pass filter Opto-compressor/limiter Mid-scoop EQ Latency-free monitoring High pass filter (12dB down at 75Hz) Selectable midnight blue porthole meter Main output features both balanced and unbalanced output Optional Digital Output (S/PDIF) External word clock input provided on BNC connector A strip of sizzling sound! Order today. |
Re: How do I connect an external mic pre amp to the mbox 2?
The Trackmaster Pro is a decent mic pre for the money. It is similar to other Focusrite mic pres in the silver range. Don't expect it to compare to the ISA range or the Red range however. You would simply connect it to the 1/4" line in ports on you MBox 2.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
They are the same pre’s that they put in the Control|24, personally I don’t use them for anything other than talkback, not my thing at all... In fact I would use the Pre’s on the 002R over the Platinum ones, I have never used the MBox 2 Pre’s but I wouldn’t be at all surprised if they were nicer than the Platinum ones.... Have a listen before you buy, you might find something you like more for the money, maybe a FMR Really Nice Pre or something else cool there are loads of options... N |
Yeah, you're correct. Platinum instead of silver. It was late at night.
Obsidian Dragon
I actually have the Focusrite Voice Master but for some reason
when I hook it up to the Mbox's inputs it makes this high buzzing noise and it's extra loud so I just use the mbox's pre's.
MBox 2 Mini Pro Tools 7.4 - MPTK Sony VAIO VGN-NR120E Windows Vista Home Premium |
You can also use the s/pdif out on the preamp in to the s/pdif on the mbox, then you will have a total of 3 inputs.
I have the Mbox mini.
the pre amp i has does that to. do u know why it makes that noise?
What's the correct way to connect an external preamp into Mbox 3? | bched | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-23-2011 04:06 AM |
How to connect external mic press?????????? | idolizetravis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-02-2005 12:57 PM |
Again.. how do I connect an external fx to 002 | lonestarparis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-24-2004 12:44 PM |
how connect external fx to Digi 002? | lonestarparis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2004 10:59 PM |
External FX! Best way to connect? | mixerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-10-2003 08:01 AM |
