Old 12-28-2019, 03:48 PM
Mahkyb Mahkyb is offline
Default Advice Needed: Have PT9/10 Lic but lost Ilok
I'm getting back into using PT's and although I have
the PT9/10 License in the iLok manager I lost the
physical ilok.
Should I report it to ilok, get a new ilok and just use
PT10?
The other issue is I have Catalina. I don't think PT10
is compatible with Catalina or if it ever will be.
Thank you for any advice:)
Old 12-28-2019, 03:59 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Advice Needed: Have PT9/10 Lic but lost Ilok
You can report the iLok lost and start a case to replace the license.
PT 10.3.10 is only qualified up through Mac OS X 10.8.5 (Mountain Lion) and is not compatible with Catalina. After replacing your Pro Tools 10 license you could use that to upgrade to the current version - check this KB for important upgrade info.
linkedin
Old 12-28-2019, 04:00 PM
If the license was deposited on the iLok you *have* lost the actual
License. It’s an encrypted digital asset on that iLok.
If you most recently operated Pro Tools with the physical iLok and did not move the license then the license is on that iLok.
If you had moved the license back to your iLok account (and not on the iLok) then you can just buy another blank iLok and transfer the license to that. You need to be very clear which of these you have.
If you have lost the license on the iLok...
There are clear directions on iLok.com and Avid.com websites for dealing with a lost iLok license. You should also look at ILok ZDT and cloud licensing options for future use.
Sardi Sardi is offline
EDIT:
Others have posted better info for you. :)
Old 12-28-2019, 04:03 PM
^^ Pro Tools 9 is fine for an upgrade to current perpetual versions.
But overall given Avid is pushing ahead on subscription licensing you should look at those options as well.
Replacement license needed for Lost iLok Meshaal Licensing & Accounts 1 11-09-2015 01:22 PM
iLok Advice Needed Siegfried Meier macOS 10 01-04-2014 11:18 AM
Lost Ilok Help needed likewise Windows 1 08-01-2013 06:29 AM
Protools 8: Need advice, lost ilok dyersev3 Pro Tools SE and Essential (Win) 1 11-03-2011 10:22 AM
