Problem using Novation control surface with PT M-Powered
Hello,
Here's the hardware and software: Windows Vista Pro Tools 8.0.1 M-Audio Fast Track Pro soundbox Novation 25 SL control surface I'm connecting via MIDI cables. Here's the problem: My Novation 25 SL recognizes the plug-in I've loaded in PT. I can use the surface to control some settings, but the control surface keyboard won't allow me to play the instrument. For example, I bring up the DB-33 in PT. I can control the sliders using the Novation control surface, but the keyboard won't play notes (though I can play notes by clicking on the keys displayed on the screen). I'm sure I'm missing something fairly basic here. So far: - Set up AutoMap 3.4 - Went to Setup > MIDI > Input Devices..., and selected Automap HUI, Automap MIDI, Fast Track Pro MIDI In, and ReMOTE SL - Went to Setup > Peripherals > MIDI Controllers tab, and selected Type=HUI and set receive and send dropdowns to Automap HUI. One thing, each time I set up the peripherals as above (which is what the documentation I've found so far says to do), I get the following message: "Pro Tools is unable to communicate with HUI. Please power cycle HUI and check its connections." Any ideas? This is killing me. Juan |
Re: Problem using Novation control surface with PT M-Powered
Yeah, there is a similar thing happening to me as well.
I'm using a Remote Zero SL with a Yamaha keyboard running through it. I think it has something to do with the order in which you turn everything on. As I said, it's happened to me a few times, then it suddenly works after going back to it - and I can never remember quite what I did! There's also the Remote's template thingy as well.... I remember scrolling through plenty of those before getting it to work. In what order are you turning everything on? |
I wondered about that, too. And actually tried rebooting a few of times during the seven hours I spent trying to puzzle this out over the weekend. That said, here's the order in which I power up:
1. Power strip 2. ReMOTE SL 3. M-Audio soundbox 4. Computer Sounds like there may be compatibility issues. I'm seriously tempted to return the ReMOTE and exchange it for an 61-key Axiom. I would hope I wouldn't have compatibility issues if I was using all M-Audio components with PT M-Powered. Juan |
I understand completely how something like this can get you down, but the Novation controller did receive some great reviews - higher than that of the Axiom from what I've seen.
Automap 3.4 does make mention of better Pro Tools templates as well. I'll admit that I haven't tried the Remote on absolutely everything within Pro Tools (MIDI Learn for example), because I'm still out of habit relying heavily on the mouse. But I'll also admit that I may not exactly understand your problem, as I have the Remote Zero SL (no keys), with a separate keyboard connected. Another difference is that I'm on Windows XP (not that I believe that has anything to do with it). I would suggest e-mailing Novation support, but I understand if you've lost faith and want to exchange (I think the guy on the digidesign online tutorial videos is using an Axiom isn't he?). Being disgruntled about a product will definitely effect the quality of the music you're making - you need to be happy and confident, and that will instill motivation. |
Novation Automap 4.2 plugin control problem | kingtinker | macOS | 4 | 03-12-2012 08:33 AM |
Novation X-Station as a MIDI control surface | o'davy | MIDI | 2 | 12-16-2007 08:09 PM |
Novation Remote SL as a HUI Control Surface for PT 6.7 | vo.van | Tips & Tricks | 1 | 12-11-2007 04:29 AM |
cs 10 control surface for Protools M-powered 7.4 | catalin rasvan | Pro Tools M-Powered (Win) | 6 | 11-21-2007 08:55 AM |
PT 6.4 Control Surface Problem | PatrickJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-20-2005 04:37 PM |
