#1311
Re: i7 Builds - Specs and Results
this cannot be correct. do you mean 24 bit and 44.1k - 48k - something in here somwhere. something is fouled somewhere, and i am not sure where to start. i am wondering if the os hard drive could be an issue. your ram timings are set at 8-8-8-20. is that the recomended for you ram?? if not change them. maybe try changing your cpu performance back to extreme.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#1312
Hi everyone. This is my first post on these forums in a loooooooong time. But I just wanted to say thanks to everyone working on the i7 quad thread. I had mine built by ascendtech.com (not sure if I recommend them yet) and received it a couple weeks ago. It was built mostly to guitardom's specs. Anyway, it's already immeasureably better than my laptop before it, but it's not perfect yet. I've had two blue screens of death and numerous access violation errors in PT 8cs3. My dverb test wasn't all that great at first either. I was only getting like 150 dverbs (PT8) at 64 buffer setting. But that was on my internal drive (I got two in the computer). When I tried doing the test on my firewire drive, I got up to 239 dverbs at 64 buffer.
I'm not overclocking, but it's set to "turbo" in the bios. Here are my sandra specs, I hope you guys can point me in the right direction. Thanks, jonnn ***** Start of Report ***** -------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < System > Model: Gigabyte Technology Co., Ltd. EX58-UD3R Workgroup: WORKGROUP Host Name: jlesher User: Jon Lesher < Processor > Model: Intel(R) Core(TM) i7 CPU @ 9200 @ 2.67GHz Speed: 2.8GHz Cores per Processor: 4 Unit(s) Threads per Core: 2 Unit(s) Type: Quad-Core Integrated Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache: 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing < System > Mainboard: Gigabyte Technology Co., Ltd. EX58-UD3R BIOS: Award Software International, Inc. F3 (12/30/ 2008) Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 3GB DDR3 < Chipset > Model: Giga-Byte X58 I/O Hub Front Side Bus Speed: 2x 2.4GHz (4.79GHz) < Chipset > Model: Giga-Byte Core CPU Generic Non-Core Registers Front Side Bus Speed: 2x 2.4GHz (4.79GHz) Total Memory: 6GB DDR3 Memory Bus Speed: 2x 532MHz (1GHz) < Memory Module(s) > Memory Module: Super Talent SUPERTALENT 2GB DIMM DDR3 PC3- 10700U DDR3-1334 (8-8-8-24 4-32-10-5) Memory Module: Super Talent SUPERTALENT 2GB DIMM DDR3 PC3- 10700U DDR3-1334 (8-8-8-24 4-32-10-5) Memory Module: Super Talent SUPERTALENT 2GB DIMM DDR3 PC3- 10700U DDR3-1334 (8-8-8-24 4-32-10-5) < Video System > Adapter: NVIDIA GeForce 8500 GT (16 SP 1.7GHz, 512MB DDR2 2x400MHz, PCIe 1.00 x16) < Graphics Processor > Adapter: NVIDIA GeForce 8500 GT (16SP 918MHz, 512MB 2x400MHz) < Storage Devices > WL750GSA1672 750.2GB (SATA300,:699GB (C:) WL1000GSA1672 1TB (SATA300, NC:932GB (F:) HL-DT-ST DVDRAM GH15F (SATA150:N/A (D:) HL-DT-ST DVDRAM GH15F (SATA150:N/A (E:) < Logical Storage Devices > Hard Disk (C:): 699GB (NTFS) @ WL750GSA1672 750.2GB (SATA300, NCQ, 16MB Cache) Audio (F:): 932GB (NTFS) @ WL1000GSA1672 1TB (SATA300, NCQ, 32MB Cache) Optical Drive (D:): N/A @ HL-DT-ST DVDRAM GH15F (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:): N/A @ HL-DT-ST DVDRAM GH15F (SATA150, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:): N/A < Peripherals > LPC Hub Controller 1: Giga-Byte LPC Interface Controller LPC Legacy Controller 1: ITE IT8720F Audio Device: Giga-Byte HD Audio Controller Serial Port(s): 1 Disk Controller: Giga-Byte 4 port SATA IDE Controller Disk Controller: Giga-Byte 2 port SATA IDE Controller Disk Controller: Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1: Giga-Byte USB UHCI Controller #4 USB Controller 2: Giga-Byte USB UHCI Controller #5 USB Controller 3: Giga-Byte USB UHCI Controller #6 USB Controller 4: Giga-Byte USB EHCI Controller #2 USB Controller 5: Giga-Byte USB UHCI Controller #1 USB Controller 6: Giga-Byte USB UHCI Controller #2 USB Controller 7: Giga-Byte USB UHCI Controller #3 USB Controller 8: Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1: Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link- layer Controller SMBus/i2c Controller 1: Intel 801xx/63xx SMBus < Network Services > < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance: x86 -------------------------------------------------------------------------------- ***** End of Report *****
Jon Lesher Mixing Engineer Editor jonlesher.com thedrumeditor.com Studio pre-production guide Drum recording guide |
#1313
UPDATE YOUR BIOS!!!! you are quite a ways behind. you should be at F6, you are on F3. as posted before... in your playback engine try dropping your disk buffer to level 1 and in your prefs drop your open ended record allocation to 10 min. ALSO:: could you try disabling BOTH of your cd/dvd drives in your device manager or bios either way and try testing again. trash your databases/preferences/ app data via digi tech support utility or my app trasher. use the search function to find them. then restart the machine and try again.
#1314
Asking the above question again.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#1315
you must have missed it, i posted the answer a few posts back. it dictates possible hard drive problems and improves their performance. details on the said post
#1316
Thanks
#1317
trust me it was A LONG night last night. my bios set ram defualt timing to 8-8-8-20 My ram Specs timing is 8-8-8-24 i havnt tweaked them tho.dont know how too. i did change my cpu back to extreme tho.
GIGABYTE GA-EX58-UD3R | CORSAIR DOMINATOR 3GB (3 x 1GB) 240-Pin DDR3 1600 | Intel Core I7 920 | PT8LE Mbox 2 http://www.facebook.com/BeatBlockedProductions |
#1318
no problem, easy to get lost in here....................
#1319
so was it 44.1 or 48 or somthing else for the sample rate????
#1320
Re: successfully running i7's, i have a question::::
i am running all 32mb cache hard drives in my system.
does anyone have a well running machine with comparable dverb numbers that is running a 16 mb cache OS drive and just a 32mb cache for tracking????? not sure if this could be a problem for a few. have a few users with problems that are running this setup.
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
