USB Keyboard crashing PT9
After many troubles I finally have PT9 up and running on my 2x2.66 Intel Xeon.. as long as I don't have my evolution MK-249c USB keyboard plugged in. As soon as PT9 sees it, the session disappears and the warning comes up that pro tools has unexpectedly quit.
The AMS recognizes the keyboard and makes a noise with the test midi feature and the keyboard also appears in the peripherals, but as soon as I activate the peripherals settings, it shuts down. A Frontier Tranzport works in the peripherals no problem. Oh, same story with an Oxygen 49 connected instead of the MK-249c. I have done reinstalls, trashed prefs, trashed .plist info.. everything I could find online to try. Hoping someone here could help a brother out. Anyone? |
Re: USB Keyboard crashing PT9
Bump!
With all the PT9 issues, someone has to have come across this. Feel free to chime in and tell me your USB keyboard works fine with PT9, at least then I'll know there is hope! |
You are on a PC ?
Cause on Mac we all use USB Keyboard without any issue. That's Mac OSX DUC, better go to ask at Windows specific DUC.
wolfgang funk marrakech prod www.marrakechprod.com www.linkedin.com/in/marrakechprod https://pro-labs.imdb.com/name/nm3047395 ------------------ Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX. |
That is the weird thing, I've never owned a PC. this is all happening on a Mac. I guess I should of said a Mac 2.66 x 2 Intel Xeon.
So, when you bring PT up with the keyboard plugged in, PT never initializes?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
New info... I can get the usb keyboard to work in the MIDI track/ Aux input set up. I can play, record, etc. It is selectable in the MIDI controller section of Peripherals but works with "none" as the selection.
To answer your question, if the keyboard is selected in the MIDI controller section of Peripherals before a session is open, then no, the session will never open and I get the Pro Tools suddenly quit warning. I can open a blank instrument track with the MIDI/Aux still running and everything still works. If I slide my instrument from the MIDI/Aux to the Instrument track, it also works. I'm surprised! Still, "none" is selected in MIDI Controllers from Peripherals from the Setup drop down menu. This should not be the case, should it? Shouldn't it have to be selected? If I delete the MIDI and Aux tracks, I can now play and record on the instrument track, with the keyboard still unselected in MIDI controllers. (I'm doing all this as I'm typing, so this is all news to me). And now if I select the keyboard, it crashes. Upon restart, I did not create MIDI/ Aux track, but did create Instrument track put an instrument on the track and nothing happened. I selected the keyboard in MIDI Controllers... crash. I guess I did find a work around, I just recreated the MIDI/Aux slide to Instrument and it worked again. I'd rather have everything work properly (obviously). If anyone made it through this post and has some ideas please post! |
Okay, I was confused after reading the original post. At first I thought the evolution MK-249c was a third party computer keyboard (you know, a QWERTY keyboard used for typing and general computer input). I was wondering how a simple USB keyboard would cause PT9 to not work.
As I read more, I realized that he is referring to a MIDI keyboard (piano/synthesizer type). So since that is the problem it makes sense that PT9 may have problems with it if the driver is not compatible or the setting s don't match between the device and Protools settings. You are probably better off contacting the manufacturer of the evolution MK-249c keyboard about an updated driver and/or the proper setting to use with PT9.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.4 running Protools 2024.3 Mac Studio M1Max - 64GB MacOS 14.3.1 running Protools 2024.3 |
RTAS Capslock Keyboard? Midi Keys triggered from computer keyboard. | aasteveo | Pro Tools 9 | 0 | 11-06-2011 06:17 AM |
Keyboard Shortcuts-Apple Thin Keyboard | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2008 03:17 PM |
Keyboard shortcuts with foreign keyboard | torsig1967 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-08-2006 05:06 AM |
QWERTY keyboard as MIDI keyboard? | Herkimer | MIDI | 5 | 08-21-2006 12:07 PM |
keyboard shortcuts without an Apple keyboard? | doublestakked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-22-2006 05:04 AM |
