Old 12-05-2015, 02:25 PM
[email protected] starfields@aol.com is offline
Default Pat 10HD with MacPro and PCIE TDM cards
Is anyone out there successfully running Protools 10HD on a MacPro with PCIE TDM hardware?
I just recently upgraded to a MacPro 2x2.93 ghz 6 core (12 core) with 32g RAM running 10.8 OS and Protools 10HD, and can't get PT to see the cards in the hardware setup window. I may have to do a clean install of Mountain Lion OS. I just want to make sure that this can be done. Any help would be greatly appreciated.
Thx - Starfields
Old 12-05-2015, 02:45 PM
Default Re: Pat 10HD with MacPro and PCIE TDM cards
Do you have an actual Pro Tools 10 **HD** asset on an iLok connected to the Mac? Don't assume, confirm the license asset is actually a HD one.
Remove any other iLoks and USB peripherals.
Does Pro Tools 10 HD then start up OK if Built-in Output is selected as the playback engine?
You did a full clean install of Pro Tools 10 on a full clean install of OS X? (no upgrades)
You are following the exact steps in the Pro Tools 10 Installation Guide?
What options shows up as the playback engine? (not in hardware)
What cards exactly are installed?
What does Digitest show when you run it?
What exact model/date code is the Mac Pro?
If you do a clean OS X and Pro Tools install, I would start over with a blank HDD or even better SSD and install on that and not mess with your current boot parition.
Old 12-05-2015, 03:49 PM
I have a PT 10 HD license. Protools opens fine with the default internal i/o selected. In playback engine, TDM hardware does not show up.
Old 12-05-2015, 03:58 PM
Craig F Craig F is offline
will DigiTest see the card(s)?
Thank you,
Craig
Old 12-05-2015, 08:54 PM
Barry Johns Barry Johns is offline
Check out my signature, you'll see that I'm running HD 10, with three TDM cards in my recently upgraded 5.1 12 core mac pro.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-06-2015, 12:21 PM
Larold Larold is offline
I have been running an expansion chassis with 6 accel cards, PT 10.3.10 for a while now. Occasionally the output would default to Aggregate IO. It drove me nuts for awhile. I found that I had to use a specific startup sequence....the Expansion chassis, external HD's, Big Ben, the 192's and then the computer, waiting to let each device fully star up.
I just got a 12 core...like YESTERDAY... with 48G Ram and it really runs well now.
I would suggest making double sure the wiring is correct, run digitest, and restart.
The ProTools pref utility is always handy for trashing stuff.
Hope this helps.
Old 12-22-2015, 09:04 AM
soul's Avatar
soul soul is offline
Try taking out all of the cards except for the Core, see if TDM shows up. Obviously run Digitest on all cards too.
PT HD4 10.3.8 / Mac OS 10.8.2 / Intel Core i7 3.4Ghz / Heat / X-Form / McDSP / Eventide / Soundtoys / UAD-2 / Ableton Live 9 Suite / NI Komplete 12
PT 10HD compatibility with MacPro 3,1 [email protected] Pro Tools TDM Systems (Mac) 3 11-25-2015 06:32 PM
Pro Tools 10HD vs 8HD + Accel cards Parks Pro Tools 10 17 07-21-2015 06:30 AM
HD 3 Core PCIe and 2 Accel Pcie cards JonGon Buy & Sell 0 04-05-2015 09:02 PM
10HD nAtive + Universal Audio UAD-2 QUAD PCIe card bacchus40 Pro Tools 10 8 05-29-2012 05:41 PM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-15-2011 11:35 PM
