Old 07-10-2013, 02:18 PM
right beside right beside is offline
Default Printed click is off the grid???
when I print my click track, it is consistently off the grid. The very first beat in any session is dead on, but then all subsequent beats are off by the same amount.
I've tried this with ADC both on and off, and it is them same in both cases.
Is there some setting I'm overlooking? I remember a click error/patch fix in an older version of PT, maybe there's a problem again in this version?
I'm trying to print my click so I can include a bar of it at the beginning of some ftp sessions. But if it's off, that's of no use.
PT 10.3.5
OS X 10.8.3
MBP 2.6 GHz i7
Old 07-10-2013, 02:21 PM
Default Re: Printed click is off the grid???
Here's a screenshot of the chaos:
Old 07-11-2013, 07:07 PM
Nobody else has this problem? Or knows why I might be having it now? It doesn't seem like its off erratically (yet.) It stays consistently off by the same amount.
Yes, for the purposes of my project I can just cut and paste it to the grid, but I shouldn't have to and would still like to know why it is so.
Old 07-12-2013, 08:50 AM
mickelini's Avatar
mickelini mickelini is offline
fwiw, I tried this on my rig. Consistently only about 60 samples late to the grid, including the first one. Tried at two different buffer sizes, and with and without ADC. Always the same results. Sorry I can't help.
Old 07-12-2013, 12:43 PM
Thanks for trying and posting your results. I just tried on my system again at different buffer settings and the amount of delay changed with the buffer. But it was always late. ADC on or off made no difference.
And it seems that the first click of a session being dead on was a fluke of the session in which I first saw this problem. In every other session I've tried since then, it's off like the rest of them.
So, I'm guessing that it's the delay of the plugin's processing. I just thought PT would be able to compensate for that with ADC on and set to 'long'.
It also gives more delay than a convolution reverb. It's the stock click plugin.
What I mean is: if I throw a conv. reverb on a mix stem and then print that stem, and i also print the click, the click is off by a greater degree than the printed stem.
Old 07-12-2013, 02:42 PM
Make sure that the option to Ignore Errors in the Playback Engine settings is unchecked.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-12-2013, 06:47 PM
Rail,
Thanks for chiming in. That fixed the latency issue. I tried it at different buffer settings and it was fine except for at 32. In that case, after initiating record with command + spacebar, my keyboard became unresponsive and only my control surface would work to stop recording and start/stop playback again.
When I unchecked that box there was a warning about click and pops. Is that a concern? Meaning, am I only unchecking this box to print an accurate click, and then re-checking it, or is it something that's better left unchecked all the time?
Thanks again.
Old 07-13-2013, 02:17 AM
Leave it unchecked. The default is for this to be checked using some drivers... so (un)check it after updating Pro Tools.
Rail
Platinum Samples
Old 07-13-2013, 07:39 AM
mickelini's Avatar
Rail
Wow. This does make a difference. I guess it pays to RTFM
Click vs Grid L-Dogg macOS 1 01-27-2013 07:11 PM
TDM Click plug is off grid khoop Pro Tools TDM Systems (Mac) 3 01-25-2007 02:10 PM
grid mode/click juju Tips & Tricks 2 05-06-2003 12:17 AM
Click and Grid studio rec Tips & Tricks 4 01-25-2003 12:24 AM
Grid to Click / Generating Click Frookie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-18-2000 07:38 PM
