Old 03-26-2013, 12:33 AM
crashhak crashhak is offline
Default firewire light is off
Protools 8.4 is working well on vista but when I'm try to use on window 7, protools doesn't work because firewire light(1394) is off.
Firewire light is on vista but off on Window 7. I need help....
Window 7 Ultimate 64bit SP1
Eleven Rack
Digi 002 rack
Old 03-26-2013, 01:22 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: firewire light is off
Eleven Rack
Digi 002 rack
Do you mean Pro Tools LE 8.0.4?
The Eleven Rack is USB not firewire. So you must be talking about the 002 which is firewire. What is your setup like? Do you connect the two interfaces with SPDIF, or do you just want one at a time? You can plug the 11R in with USB and don't need the 002 running.
For PT LE 8 running on Windows 7 you should update Pro Tools to 8.0.5
http://avid.force.com/pkb/articles/e...667?popup=true
Make sure you have the updated drivers and not the beta. Read through the page linked so you get the process right.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-26-2013, 07:34 AM
CeresRegnum CeresRegnum is offline
as Benoi mentioned the 11r is USB, but as far firewire goes. I know that Windows 7 has issues with it and you have to change drivers/config manually to the Legacy Version, for it to work well with Windows 7. I had a massive issue with my firewire drivers on 7, with my Pre-Sonus and changing to the legacy device drivers in Device manager fixed the problem.
Good Luck
Ceres~
Mac Book Pro 2012 - OS X Ver. 10.8.3
Eleven Rack
Pro Tools 10 - Ver 10.3.2
Mac Book Pro 15" Monitor Specs - 2.6GHz Quad-core Intel Core i7, NVIDIA GeForce GT 650M with 1GB GDDR5 memory, Samsung SSD 250GB, 16.0GB PC3-12800 1600MHz DDR3L
Old 03-27-2013, 12:25 AM
Thank you guys. I updated to 8.05 and now it works well with window 7. Time to create new music
Digi 002 Rack: Firewire Link Lost - no 1394 light PacoPoblano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-03-2016 08:05 PM
Mbox Pro Firewire Not Recognized (Light Show) chritaro FireWire & USB Audio Interfaces (Mac) 0 05-11-2013 01:06 PM
unable to locate digi 003 hardware, Firewire light doesn't come on groversi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-23-2011 04:19 PM
Firewire keeps dropping out (1394 light goes off) Kazin187 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-30-2006 08:41 AM
Digi002R firewire light has gone off? Tubedriver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2005 02:06 AM
