Old 12-24-2012, 01:31 PM
2hip2b4real 2hip2b4real is offline
Default Registry Error on Mountain Lion
I'm trying to open PT 10.3.3 on Mountain Lion and I'm getting a window saying:
Registry Error....Please insure this product has been installed properly.
Old 12-24-2012, 02:03 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Registry Error on Mountain Lion
Originally Posted by 2hip2b4real View Post
I'm trying to open PT 10.3.3 on Mountain Lion and I'm getting a widow saying:
Is this a fresh install or upgrade from an earlier version if PT?
I would start by doing the following..
Run the uninstaller to do a clean uninstall
Trash prefs user library prefs...
-Delete 'com.digidesign.protoolsLE.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences'.
Empty trash
Repair disk permissions
Reboot mac
Download installer again!! Incase previous installer was corrupted!!
Install again
Make sure you have the latest ilok driver installed
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-24-2012, 03:25 PM
Those Pefs aren't there to delete. The Digidesign Mini Grand and Expand are there. Done all the uninstalls and re installs.
Old 12-24-2012, 05:16 PM
Are you running as an Admin?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-24-2012, 08:25 PM
Yes. The problem is some old plugins I need to remove but I don't know where they're located.
Old 12-24-2012, 09:19 PM
Google or searching this forum will fix that problem for you (and many more).
Here is a direct link. http://www.pro-tools-expert.com/home...d-running.html
Darryl
Old 12-24-2012, 09:51 PM
The problem is I'm not fining the right Library because there are no Avid or Digidesign folders in there.
Old 12-24-2012, 10:11 PM
"In where" exactly. There are multiple different locations. Give the exact path you are trying to follow. You are not looking for a "library" (a technical computer term) you are looking for a plugin folder containing a bunch of files.
And back up one. What exactly have you done so far? If you have done a clean uninstall (i.e. used the Pro Tools uninstaller with clean option) then all the plugin files have been removed by the uninstaller. Did you do that like you said? Then why are you still trying to remove plugins?
Have you actually done all the standard deletion of prefs and databases? By following the exact instruction? Including the need to hold down the Option key and use the Go menu in the finder to get to the now hidden user libraries? If you try that and "things are not there" again give an exact path of what is not there.
We can't keep guessing what you are doing, you need to exactly describe each step (like how exactly did you uninstall/remove the last install?).
Go precisely down the list Crizdee already gave you and say exactly whether you have done each step and if not what the problem was. Which is pretty much a recap of where you should have started by following the standard troubleshooting guides (this one is for Lion but work for Mountain Lion as well) at http://avid.force.com/pkb/articles/e...791?popup=true These are linked from the "Help us Help You - READ THIS Before Posting!" link at the top of this page, if you have really not read that you should. Those instructions will describe the Option key trick necessary to see your user library folder contents.
Darryl
Artist Control Display error with OSX Mountain Lion bg_isagenix Artist Series 5 10-01-2015 01:58 PM
Mountain Lion / DAE 720 error topazuk Pro Tools M-Powered (Mac) 2 12-25-2013 06:08 AM
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION DESVED Pro Tools HDX & HD Native Systems (Mac) 2 05-21-2013 03:18 PM
lion -> mountain lion question grant howarth macOS 3 05-01-2013 01:24 PM
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? EricWillhelm macOS 9 01-11-2013 10:55 AM
