PT 9 / Axe Fx 2 connecting
Has anybody been able to use the Axe Fx as an audio interface into Pro Tools 9? All I want to do is send audio via the USB from the Axe Fx 2 to my Pro Tools. When I go to create a new track in 9 the Axe Fx isn't an input option on the track. Any ideas?
Re: PT 9 / Axe Fx 2 connecting
I'm not aware of a way to have an AXE (or a similar USB device) pop up so easily within ProTools. Not just any USB device can be used with PT, not without the proper communication. Has this been implemented?
Unfortunately, it's a bit more complicated to get an Axe to show up in your list of available devices. |
You'll need to check that Fractal has drivers for the Axe that support Pro Tools.
Your interface should show up in Pro Tools>Setup>Hardware and also Pro Tools>Setup>Playback Engine. If it shows up in Playback Engine go to Setup>I/O and click Default button. Your I/O's should then be displayed as an option in each channels I/O selector.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
I think I'm explaining this wrong, sorry I'm not great with computers.
This is what I want to do. I want to use my Digi 002R as the playback engine but use the USB from the Axe Fx to send audio to pro tools. Is that possible? Thanks for all the help. |
I'd assumed that's what you meant. I'm unaware of any method of doing it.
No, but you can use S/PDIF.
The thing is, the Axe FX only operates at 48K so your PT session would have to be 48K too.
Is connecting 2 x 96 i/o and an 888 possible? | nullstudios | Pro Tools TDM Systems (Mac) | 3 | 09-14-2011 10:52 AM |
connecting | sparks arson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-09-2011 06:59 AM |
Connecting 888/882-20/882 | nomatik | Digidesign Hardware & Software | 1 | 09-02-2006 03:28 PM |
connecting a PC to Mac | therockstar30 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-02-2005 08:53 AM |
need help connecting my mic pre to 001 | djc8902 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-27-2004 05:58 AM |
