Old 02-07-2008, 02:50 PM
blizzard's Avatar
blizzard blizzard is offline
Default Midi Fader Volume - Instrument & Midi Track
I am trying to wrap my head around some MIDI techniques.
-> I set up an Instrument Track.
-> Insert VSTi on Instrument Track
-> Create multiple MIDI tracks to control seperate inputs on VSTi
-> Record a pass with MIDI
** Why doesn't the MIDI volume fader control the volume of the Instrument upon playback? **
I'm assuming it has something to do with "CC" data within the MIDI track.
Any insight?
Cheers,
Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9
Old 02-08-2008, 05:38 PM
domen74 domen74 is offline
Default Re: Midi Fader Volume - Instrument Track
There's a difference between midi volume and audio track volume... on an instrument track you'll see you can pick two volumes...the bottom one corresponds to the audio fader.
Old 02-18-2008, 04:56 PM
blizzard's Avatar
What I'm trying to figure out is why won't the faders from the multiple midi channels change the volume of the instrument playing back.
Here is another scenario..
I have an Stereo Aux channel with Kontakt loaded.
Within the Kontakt plugin I have 8 different instruments loaded.
I have 8 seperate midi channels, each sending midi data to one of the instruments within Kontakt.
**When playing back, I can not change the individual volume of each instrument by moving it's corresponding fader, nothing happens.**
Is this normal? If so, how do people mix with a setup like this? It seems problematic and time consuming.
Any advice?
Cheers,
Andrew
Old 03-11-2010, 09:35 AM
Reesho Reesho is offline
Default Re: Midi Fader Volume - Instrument & Midi Track
Blizzard did you ever solve this problem? I'm dealing that exact issue right now!
Mac Pro 2x3.46 Ghz Dual 6-Core Intel Xeon
64 GB Ram
OSX High Sierra 10.13.6
PTLE Subscription - pending
Interface - pending
Midi Controller =M-Audio Axiom 49/USB2
midi track record turns off all other midi/instrument tracks delay comp holyspicoli Virtual Instruments 4 07-18-2013 06:14 AM
Can't drag midi into midi/instrument track from os or ezdrummer/addictive drums NJ Soul macOS 7 05-28-2011 10:09 AM
Instrument/midi track will not recorgnize midi signal. tonyshred 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-13-2007 10:42 AM
Can I automate midi instrument midi volume slider? ChaplainPC MIDI 6 07-08-2006 06:33 PM
Crash when adjusting Instrument track MIDI volume Helge Krabye Pro Tools TDM Systems (Mac) 0 01-28-2006 02:33 PM
