7.4 Grouping problems.
I just can't seem to figure out how to get my groups to work. I am doing my normal grouping routine.... (add group and setting attributes) But afterwards my solos and mutes aren't linked, when i select a track that is with in the group only one reacts. My faders aren't linked.... Whats the deal?? Am I missing something? A little help would be appreciated. Thanks.
Aaron
Aaron Ersoy |
Re: 7.4 Grouping problems.
Do you have VCAs assigned to those groups?
no. Give me the full details on grouping so I can make sure I am doing everything correctly.
Aaron Ersoy |
It sounds like you already are but a VCA would override those settings (on purpose), that's why I asked.
Easy question, but are your groups active? You can see if they're bold or grayed out in the groups list in the lower left corner of the Edit window
they are active, how do you check if VCA is engaged?? Would this cause my mute/solo groups to stop working? Thanks for the help.
Aaron Ersoy |
Incidentally, the PT Reference Guide is fully searcheable. For example, type “VCA” in the search field found at the top-right corner of the document. (If you don’t see the search field, select “Drawer” from Preview’s “View” menu.) This makes it extremely fast to search and learn about ProTool’s many features. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
More likely you need to check your globals.
Cntrl+Cmd+G (Modify Groups), then click on the Globals tab. From there, you can check the items that you want grouped: solos, mutes, etc. This one got me recently, too.
Pascal Garneau | IMDb |
Thanks for all the help. I'll be trying all this out.
-Aaron
Aaron Ersoy |
Looks like the global thing was the issue. Did they change this in 7.4 hd? I have never ever had to set the globals before.
Aaron Ersoy |
Grouping problems | Nathan W. | Pro Tools 9 | 1 | 02-04-2012 04:18 PM |
Grouping problems! All group won't work, grouping channels together spontaneously | farmfresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-18-2009 09:57 AM |
Grouping | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-06-2008 10:29 AM |
Grouping | Mofoman | Pro Tools M-Powered (Win) | 4 | 11-30-2007 08:22 AM |
FX GROUPING | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-06-2006 11:39 AM |
