i can\'t record with my new mbox mini
hi everyone.
i just got a new mbox mini today, started editing a session with a few tracks i had previously recorded on DP and everything went fine. then i started a new session, plugged in my ribbon mic in my preamp, the preamp to the interface's input 1, got the signal in my headphones (very bad, distorted signal, by the way), also tried using the attenuation pad. so i record-enabled the mono audio track, set the input correctly, but all i got was noise, a continuous signal, and that was all i could record - not what i could hear in my headphones. finally, i tried to just use the mbox's preamp through the xlr input and i had the same problem. i checked the I/O setup and everything looked fine, what should i do? please help. thanks, silvia |
Re: i can\'t record with my new mbox mini
Did you by any chance put your Mac to sleep while Pro Tools is open?
PPC G5 Dual 2.0, 8.5G Ram PT 8 cs2 OSX 10.5.8 MBP Core 2 Duo 2.16, 2G Ram PT 8 cs2 OSX 10.5.8 Mbox 2 Pro, Mini, Micro |
Can't record Mbox Mini 3 in Windows | l4nc3rr | FireWire & USB Audio Interfaces (Win) | 1 | 02-27-2014 03:52 PM |
MBox Mini won't record live audio?! | ChinskyBeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-20-2012 02:28 PM |
MBox Mini/Pro Tools 10 playback/record issue | Ewan T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-11-2011 03:54 AM |
Mbox 2 Mini and Record Player problems | Adamithero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-14-2011 05:29 PM |
SPDIF - How to record with Apogee Mini Me & Mbox 2 Pro | rhinostylee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-04-2008 08:25 PM |
