Old 10-07-2006, 08:22 AM
Default Frame Sync or Frame Store - Plasma v. CRT
I have an issue. It's that a studio has a CRT for the engineer and a plasma for everyone else. The two are positioned such that it is obvious one lags the other. Everyone I have spoken with says to delay the CRT to match the plasma, then delay the audio monitoring path to match the video. I can grasp that concept fine. The issue is how to delay the CRT? I need two (2) frames of video delay for it. The only products I can find to date are from For-A and GrassValley, and each one is card-based and meant to be installed in a frame.
Has anyone else had to solve this problem in the past? Could anyone recommend a device that will delay video by two (2) frames? Thanks for reading!
Old 10-07-2006, 12:02 PM
philper philper is offline
Default Re: Frame Sync or Frame Store - Plasma v. CRT
MANY years ago we used to have little inline frame delay boxes made by a company called
AVCOM that would be patched into the lines in MCR @ an edit house. Isn't there anything like that anymore?
Philip Perkins
Old 10-07-2006, 12:50 PM
minister's Avatar
minister minister is offline
hey chief,
here is some nice reading from a thread Rail started... it includes a link to a device.
Rail Thread
my simple solution is to calculate both and switch based on my needs.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 10-10-2006, 08:50 AM
Hey Minister,
Great find! Either I wasn't searching properly or not searching long enough. There is a product in there that would fit my short term needs for sure.
HTML code is On
video on second screen lags on frame by frame moves gonzalo.garcia macOS 4 11-14-2012 09:13 AM
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 11:39 AM
frame dropouts/frame jump when synced with 02rv2 Alécio Costa Pro Tools TDM Systems (Mac) 1 11-24-2005 12:03 PM
Snap to Frame... Strip Silence to Frame? chanlon25 Post - Surround - Video 2 07-13-2005 11:54 AM
Sync and frame rate sobeauty Tips & Tricks 0 07-01-2002 08:59 PM
