Anybody try or have ssl\'s duende
seems pretty interesting. needs the vst wrapper so i was curious if this ran smooth on pt 7.2
thanks in advance zeeman
MAC OS 13.6.1 Mac Mini M2 16gig Ram PT 2023.12 Lynx Aurora 16n Thunderbolt |
Re: Anybody try or have ssl\'s duende
Yes, and its a great box tho you have to be aware of two things:
1. its got latency, - so wont work for tracking. 2. the box is new, drivers is not there yet, it wont crash PT, - but there are glitches... |
have you compared it to the waves ssl's? (i know they are different consoles).
are the comp/gate more sonicly flexible than the 4000? tell us more if you can...... Thanks!
www.LiveFromDarylsHouse.com |
- more info and insight Duende and Waves SSL
I love the sound. It's without question the best eq and compressor I have for ProTools and I've tried all the big dogs. I have NOT tried Waves SSL, but this comparison question has been asked many times and Duende is usually the favorite by a large margin. |
thanks pam/eric for the info.
i wouldn't be tracking with it only mixing. how bad is the latency? thanks again zeeman
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor |
from ssl's site:
EQ & Dynamics Channel Plug-In The EQ and Dynamics Channel Strip plug-in is ported from the C200 console and includes separate high and low pass filters, a four band parametric equalizer, an independent compressor/limiter and gate/expander as well as an output gain adjustment knob. Stereo Bus Compressor Plug-In Bus Compressor The Duende Bus Compressor brings the dual benefits of spectacular audio performance with a universally acclaimed compressor characteristic. Taking its sonic cues from the bus compressor found in the Solid State Logic SL 4000 G Series console, zeeman
and reading further.
Equalizer Section The Equalizer section is a classic, flexible four band parametric EQ. This plug-in includes two distinct EQ flavours, one based on the SSL G series EQ and another based on the latest version of SSL’s legendary E series EQ. http://www.solid-state-logic.com/mus...e_channel.html check it out zeeman
- yes, I´ve been using the ver. 1.2 driver since it came out, - and it helped a lot, - but try doing the "alt+shift" on 32 channels..
Offcause it all depends on how you connect the Duende to your system, dont slave it after a fw-drive -it works the best on its own ect. And the delay-compensation is allover the place.. - to give the Duende the best posible connection I even bought a fw-pci-card for it...hmmm Regarding the sound, - as said it sound great, - very different from the Waves, - I wouldnt say its better - just different. Both have that SSL-sound so its a matter of taste. |
Does HDX work with SSL's Delta link MADI? | Rockman413 | Pro Tools HDX & HD Native Systems (Mac) | 16 | 08-12-2013 11:00 AM |
Duende V3.1.0 | K.I. | Pro Tools TDM Systems (Mac) | 0 | 09-23-2009 07:28 AM |
SSL's Pro Convert... | The Weed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-16-2008 03:42 PM |
Anyone using Duende? | twix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-16-2007 10:26 AM |
Duende for PC anyone? | PTLExp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2007 03:05 PM |
