Old 05-01-2008, 07:17 PM
pawn3d pawn3d is offline
Default ERROR: \"path to session contains illegal characters ( / ).\"
I'm just trying to save a new session and I get path to session contains illegal characters ( / ).
What is the meaning of this?
Old 05-01-2008, 07:53 PM
Shawn Simpson Shawn Simpson is offline
Default Re: ERROR: \"path to session contains illegal characters ( / ).\"
It seems to mean that somewhere in the file's path (disk>folder>session), there is a slash (/) in a name. This use to happen all the time with older sessions from the days when it wasn't an issue to use slashes and we'd write out titles like 5/1/08. Since the file naming conventions have been altered to be more compliant with Windows, you're limited in which characters you can use.
Old 05-01-2008, 10:47 PM
what do I do?
It wasn't doing this yesterday!
Old 05-02-2008, 07:59 AM
DigiTechSupt's Avatar
what do I do?
Look at the entire pathname of where you're trying to save the file - somewhere in there a folder or drive name has an illegal character in it. You'll need to change the name of the drive or folder, or change the path that you're trying to save the session to.
If that is absolutely, positively not the case, it may be caused by database or preference corruption. Trashing those should fix it.
Avid Audio Tech Support
Support FAQ
Old 11-24-2020, 12:08 PM
weso weso is offline
Default Re: ERROR: "path to session contains illegal characters ( / )."
I got caught out with this and, after spending ages changing clip names to remove any underscores then realised that the name of my hardrive contained the illegal character /
I removed the / and my sessions saved fine in 20.9.1.
"Path to session contains illegal characters" beschaving macOS 5 07-30-2013 01:42 AM
path to session contains illegal characters evankertman Pro Tools M-Powered (Mac) 7 04-28-2009 03:09 PM
path to session contains illegal characters (/) basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-20-2008 08:22 AM
Path to session file contains illegal characters (/). ???? jpashley1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-15-2007 07:22 PM
Path to session contains illegal characters (/). Haiku 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-18-2007 09:30 AM
