Old 10-06-2006, 10:54 AM
minister's Avatar
minister minister is offline
Default Re: Advice on workflow and sync - film to PAL.
- What if we (sound guy) are the one doing the dailies synchronisation from 24 film -- telecine at 25? Should we pull up the sound?
seems to me this is a discussion to be had with the post production supervisor (or equivalent) and telecine people and editors both vilm and sound for each project. it all depends on workflow....
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 10-06-2006, 07:47 PM
Bokir Bokir is offline
Sorry Tom (and all) I guest I'm not saying clearly before. So let say the workflow (has been decided) as follow:
We're in PAL land:
- Shot at 24
- TC at 25
- We sync at ??
- Avid Project at 24
- Work video at 24@25
- EDL at 24
Any suggestion/correction? Thank you.
Satrio Budiono
FourMix JFS
Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4)
Old 10-07-2006, 08:36 AM
Branko's Avatar
Branko Branko is offline
Bokir,
the syncing method depends on what tools you're using for the job.
If you're syncing dailies just for screening, then sync at 25. The best way of doing so is using AATON's InDAW software/hardware. It will speed up the audio to 25 FPS and lay it back to tape (i assume you're doing the telecine transfer to some kind of tape, like Beta SP or Digi Beta). At the end of the day, AATON InDAW will be able to export those files to NLE, like AVID and you can use them in native speed projects (24FPS)
The second method is to sync them up in AVID or FCP, and then you can choose to lay it back to original Beta tape, at 25 FPS, or to output at 24fps, with picture pulldown to a new Digital Cut tape.
Of course, you can invent dozens of other ways to sync the dailies, but these two will leave an open door to the later stages of post production.
Branko
Branko Neskov c.a.s.
www.loudness-films.pt
Old 10-07-2006, 08:39 AM
Branko's Avatar
I forgot one thing: picture EDLs will be probably at 25 FPS. Cut lists at 24 FPS.
Branko
Old 10-08-2006, 12:32 AM
Thank you all for the great answers.
Branko you're spot on. Thats really explain the workflow.
But regarding working solely on ProTools environment, can you enlight me how to emulate the dailies sync workflow of Aaton inDAW? We pull-up the sound 4% for sync?
Regards.
Satrio Budiono
FourMix JFS
Old 10-08-2006, 03:29 AM
Branko's Avatar
Yep, thatt would be the answer! The problem is that the audio synced in ProTools looses all important information (TC of the original file, camera roll, shooting date, take, slate etc.) so you'll have to re-sync it later to be able to properly use it in your picture NLE system. OTOH, AATON is kinda expensive....
Branko
Old 10-09-2006, 04:48 AM
Great. Thank you Branko and all.
Satrio Budiono
FourMix JFS
HTML code is On
Workflow: Creating Film score music (template/setup/workflow) jhonny.eriksson Tips & Tricks 5 03-03-2015 10:08 AM
Film/Video Workflow smack5099 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-18-2007 06:48 PM
OT: film workflow question rhumphries Post - Surround - Video 6 03-31-2007 12:26 PM
HD Film Workflow abusound Pro Tools TDM Systems (Win) 2 01-29-2006 10:42 PM
advice needed for film music sync mfilter Tips & Tricks 0 09-30-2001 01:56 PM
