Old 08-06-2020, 08:31 AM
bluemoa bluemoa is offline
Default Avid S1 won't stay connected, won't accept firmware update
I bought a demo S1 from Alto Music and it just won't stay connected and mostly won't even show up in EuControl. When I try to update the firmware from 0.0.21.0 to the latest version which may resolve the problem, it disconnects before it can begin and displays "Could not send firmware to Avid S1. Make sure your network and power cables are firmly connected and update this unit again". The S1 then is likely to freeze up and the power switch won't work so I have to manually unplug it to turn it off.
I've tried directly connecting to a computer using the provided crossover cable and manual IP addresses, i've plugged into a switch connected to the computer and router with DHCP, without DHCP and manual addresses, port forwarding 49168, different Ethernet cables, tried it only my laptop, tried it on Windows 10, same problem, nothing works. EuControl is allowed accessibility access in MacOS. I've called Avid support but no one is answering phones. Thanks
Old 08-12-2020, 09:40 AM
Default Re: Avid S1 won't stay connected, won't accept firmware update
Can anyone help me with this? I cannot get in touch with Avid support as they are constantly busy (I get redirected to Media Composer support). thanks
Update: finally got in touch today, the unit is DOA so I have to return it. Grr
Saved presets stay or go away after Eleven Rack Firmware Upgrade? geddydawg Eleven Rack 2 03-31-2017 05:59 PM
Midi Keyboard won't stay connected cut2muz macOS 1 07-28-2013 04:29 AM
Does your iLok have to stay connected while running Pro Tools? ProMac07 Pro Tools 10 3 11-24-2012 12:37 PM
Please Help? McMix units will not stay connected shockadd Artist Series 1 08-10-2012 07:25 PM
Core Audio won't stay connected! raydsr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-25-2010 01:48 PM
