Hot signals with Digi002...HELP !!!
Hi everyone...
I am new here, proud to be part of the family. I recently purchased a Digi002 and am running it with Pro-Tools LE 7.4 on my MacBook Pro. I am a professional freelance drummer and do recordings in my studio in L.A. I also purchased a couple of BLUE mics, the Kickball and the Blue Ball for kick drum and snare drum respectively. They are phantom powered dynamic mics...(yes indeed...)...I tried recording with them the other day and was having serious problems with the input signal...the signal was WAY HOT ! I mean peaking...even with the gain at minimum...I had to turn the phantom power off to avoid it from peaking but it was still reaching the limit... I contacted BLUE and they said it's a problem with the Digi002's pre-amps...entry level they said... What can I do ?? Is it solvable ?? Or do I have to buy a separate pre-amp ?? Please help... GROM - Freelance drummer |
Re: Hot signals with Digi002...HELP !!!
What I do is plug all of my mics into a mixing board first, then send a line level to the 002. Much more control that way.
-Ryan
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
you play too loud...
sorry just kidding |
i have had good results with the digi002 recording drums at high levels, but you have to plug your mics into an external mic preamp and then into the 002. i have used a behringer ultra gain tube pre and got good sounds.i bought an api 3124+ and i am very happy with the sounds i get.
I would bet the phantom powering of a "dynamic" mic is the issue. That and they are 50-60 dollar mics.... although it is surprising what can be had for relatively little money these days. Or it could be something with your hardware. good luck, SB |
I am not to sure but i believe your mics do not have a pad switch. You can buy an XLR pad connector that gets between the mic and the cable. that should help your signal level! Or as said above use a different pre amp and get to the 002 with a line signal. Also i am sure there is other people with the same problem in the LE forum.. see what their solution is.. GOOD LUCK!
Mo |
The inline mic pads mentioned above are your best (and cheapest) bet. No, they will not degrade the sound (any more than connecting two mic cables). These are good.
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
Thanks everyone for the help ! I'll go with the pads...I only own a Eurorack mixer and I doubt it's good enough to go through for recording.
Did you try the Mic/Line button? It is actually just an 18db pad, the micpre is still in the path. This is another common complaint that you can't take the micpres out of the signal path for 1-4...
It appears to disable the XLR and enable the TRS input. You'll need different XLR to TRS cables or adapters. I just tried it with an SM-58 and it works fine.. The trim knob still works and it puts out less overall level..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
http://www.myspace.com/philogg |
How should I record dry and wet signals | YYR123 | Eleven Rack | 17 | 06-27-2013 02:56 PM |
M Box 2 USB signals in Pro Tools | Yanni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-08-2006 12:51 PM |
Trouble with MIDI IN signals in 6.4 LE DIGI002 R | JMAUL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-27-2005 10:39 AM |
Hot signals to digi002 pre's - clipping problems? | jhammer619 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-03-2005 09:15 PM |
getting my signals as hot as commercial cds | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 28 | 08-22-2002 04:24 PM |
