Putting song's on a cd from cassette tape's.
I'm putting some song's onto a cd and they are from cassettes, the client already mastered the song's. I'm using the Maxim plugin to boost the audio levels a little bit, I'm having some trouble. I think when we recorded them into pro tools the level was a little low, I'm remastering using the Maxim plugin to boost levels, what would be a good level for the final mix for the cd?
Control24, Digi 002, Rosetta 800, KRK V8's, PT 7.4 Macintosh G5 Dual 2.0 3 gbs ram |
Re: Putting song's on a cd from cassette tape's.
Also remember - for louder just turn up the volume control |
+1
It sounds like you should re-transfer them at the correct level. If the client already 'mastered' them. Then I would just use clip gain; but only on a healthy transfer. Sent from my iPhone using Tapatalk
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Given how much tape noise you probably have, I would do things in a few steps.
#1-use whatever tools you have for noise reduction and get it as quiet as you can. #2-EQ as needed(this will be a compromise between clarity and too much hiss) or use a dynamic EQ(Waves F6?) or something that can do multi-band expansion. #3-Normalize to 95%(ish) to get the level up to where #4 can have a good signal to process. #4-use a "brick-wall limiter" to get more volume(Maxim is technically the right plugin, but in reality, I've never been happy with it). My "go to" plugins would be Waves L2/L3, or Slate FG-X, or Massey L2007, or iZotope Ozone(have used all and like any of them much better than Maxim)
Something we're forgetting here is does the op have a clean connection between whatever is being used for the cassette playback and the audio interface of the recording computer. Get that wrong and the rest won't amount to a hill of beans. If it's a typical cassette machine I'd use some kind of di between the cassette and computer like something from Radial. Helps match the levels and impedance as well as take care of ground loops. Been there/done that and have made Radial Engineering stuff my go-to boxes for these kinds of things.
-2dBFS for radio hits and -1dBFS for almost everything else
I've done a boatload of cassette to digital transfers, for myself and for some clients.
Waves restoration bundle is awesome for getting the noise out.
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2 |
Originally Posted by The Egg: Be a Pro and stop being a Tool! Mac Pro Rack (7,1) 16-core 3.2gHz Intel Xeon W OSX Catalina (10.15.4) 8TB Mac OEM SSD System Drive (3) 1Tb 7200rpm audio hard drives 192Gb RAM Radeon Pro Vega II Video Card 2 Avid HDX Cards 2 Avid 8X8X8 HD I/Os; 2 Avid 16X16 HD I/Os PT Ultimate 2020.3 |
I used to love the original Soundsoap for cleaning up all kinds of stuff, especially when transferring vinyl to CD. Thing with SS is to not try and do everything at one pass but several passes. As to boosting the level until you hear distortion or artifacts that's not a good criteria as not everyone hears the same thing and thinks it's a problem. |
Cassette tape machine SPDIF connection problem | theshizon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-13-2008 06:56 PM |
transferring audio from a cassette tape player | blues376 | Tips & Tricks | 1 | 10-25-2006 02:02 PM |
Cassette Tape Hiss | Straatocastoer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2003 05:48 AM |
Tape (Cassette) Restoration Help? (For an analog newbie) | Mark Wheaton | Pro Tools TDM Systems (Mac) | 12 | 08-05-2003 10:25 AM |
From cassette tape straight into Pro-Tools, how? | gripweed | Digidesign Hardware & Software | 12 | 03-16-2003 05:28 PM |
