Old 02-11-2010, 04:15 PM
Dizzi45Z Dizzi45Z is offline
Default How bad is it to not use Combo update?
Not thinking about it, I just installed Snow Leopard update by using "Software Update." Right after I finished, I remembered that you should update with the combo update packages.
Is this something that will likely cause problems to the point that I should reinstall Snow Leopard and do the update with the combo installer?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools 12.8.3 HDX Mac OS 10.12.6
Mac Pro Quad 3.2 Nehalem with 32 GB RAM
Noisebox Studios -Utah Recording Studio
Old 02-11-2010, 04:39 PM
Craig F Craig F is offline
Default Re: How bad is it to not use Combo update?
If PT won't launch go get the Combo.
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 02-11-2010, 05:02 PM
Can I install the combo 10.6.2 over my current 10.6.2?
Old 02-11-2010, 05:16 PM
Concerttom Concerttom is offline
That's what I did, & it's worked great!
MacBook Pro, OS 10.6.2, Intel Core 2 Duo, 2.6 GHz, 4 GB Memory, 003 Factory, PT LE 8.0.3, G-Tech G DRIVE Q 1TB HD
'Wave of the future, Dude. One hundred percent electronic.' -- J. Treehorn
Old 02-11-2010, 06:10 PM
JNS JNS is offline
Did you guys install 10.6 over Leopard or do a complete clean install of 10.6 and then update to 10.6.2?
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 02-11-2010, 06:24 PM
Oli P Oli P is offline
Clean install...
www.olipoulsen.com
iMac27 i7 3.4 / 32 GB Ram / ML 10.8.5
Apollo 8 / PTHD 10.3.9 / PTHD 12.4
Old 02-11-2010, 06:38 PM
Originally Posted by Oli P View Post
Clean install...
No, just run the Combo over the Delta
Thank you,
Craig
Old 02-11-2010, 07:39 PM
Clean install, based on numerous recommendations here on the DUC (including from DigiTechSupport). Seems to have worked just great; the OS and Pro Tools are much snappier & more stable than ever. It's really not that big a pain, either. Only took a few hours total, and there's a method you can use to save your old system settings (migration assistant, I think it's called). You can then get the combo 10.6.2 updater from Apple's website for best results, & you're set.
Old 02-11-2010, 09:34 PM
Jeffrey Talbot Jeffrey Talbot is offline
I've been using PT on OSX for the moment it was "qualified"... years ago, and I honestly don't ever recall doing a combo update, although no doubt there was one or two along the way.
I'd say easily that 85% of my OS updates were done thru Software Update... No problems, that I recall..
Old 02-11-2010, 11:07 PM
Good to know. Yes. I did a clean install and I'm in the process of moving everything over.
Mac OS X v10.6.6 Update Combo (new jan.6) onepercentfree macOS 14 01-12-2011 03:50 PM
Mac OS X v10.6.3 v1.1 Update (Combo)? gthm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2010 01:19 PM
Mac OSX 10.5.8 combo update Growlyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-16-2010 05:11 PM
10.5.5 combo update... ebonyles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-12-2009 10:23 AM
PT LE 7.3.1 NOT LAUNCHING AFTER 10.4.9 combo update ! HELP waterbedman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-11-2007 06:11 PM
