Old 06-04-2001, 04:33 PM
Petra Pan Petra Pan is offline
Default MTPAV and MAC - Autostart probs
Ive got a Motu MTP AV midi-interface connected via USB to my G4 533 Mhz Computah.
When i want to turn off the Computah the Computah starts again after shutdown - friggin automaticly - against my free will.
Isnt this a free land or what!?
When I disconnect the Midi-interface (pull the usb-plug from the Computah) everything is fine just fine.
What to do?
Ohh..and Im from Sweden, only so that you know.
Mac Pro Quad 3.0, HD3Accel, 96 I/O, 5GB RAM, PT 7.4.cs2
Old 06-04-2001, 05:31 PM
T-LAY T-LAY is offline
Default Re: MTPAV and MAC - Autostart probs
I have the same problem, with a ZyXEL-omninet ISDN-Adapter connected via USB to my G4/400. Apple-Support told me it´s a bug in the ZyXEL-USB-driver. Others say it is an Apple-problem...
- simply put your G4 into "sleep-mode", this will work fine, or disconnect affected USB-device(s) before shut-down.
Old 06-05-2001, 01:39 AM
BigBear BigBear is offline
Put a powered Hub in between the G4 and the MTPAV or run the MTP from a monitor/keyboard port, not directly from the back of the G4. This has solved the problem for many of our clients!
Ciarán Cahill
ciaran@bigbearsound.com
ciarán cahill
Old 06-05-2001, 11:42 AM
Solved it.
It was simply a matter of the order in which
I turned off my EQUIPMENT.
Have to turn off computaH BEFOOOORE mtpAV.
Så.
PP
Old 06-06-2001, 10:34 AM
Sweetwater Tech T Sweetwater Tech T is offline
This is a common problem, which is easily avoided by keeping the MTPAV (or other interface) ON while you shutdown.
Also verify that you have the latest drivers for the unit (FreeMIDI1.45, MOTU USB driver 1.15).
MTPAV and OMS Problems?? JLEpperson Pro Tools TDM Systems (Mac) 3 02-20-2002 09:59 AM
MTPAV and 001 Mocha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 12-21-2001 02:58 PM
MTPAV jitter..during SEX!! batman Pro Tools TDM Systems (Mac) 7 10-26-2000 03:00 PM
AutoStart 9805 virus-Any Background Info? Joel Abrams Pro Tools TDM Systems (Mac) 5 02-23-2000 03:32 PM
autostart virus - need advice! coaster Pro Tools TDM Systems (Mac) 4 11-08-1999 11:34 AM
