Old 05-31-2019, 07:48 AM
Markrosoft Markrosoft is offline
Default Which mac OS for PT 2019.5?
I'm curious what other people are experiencing with the latest version of Pro Tools and if it seems to work best on any particular OS. I'm currently on Sierra. I figured it Mojave would be best since it's the latest and PT officially supports it but when I updated to Mojave and 2019.5, Pro Tools basically wouldn't work. I was getting crazy delays, freezing/crashing (with a weird stuck audio loop), and basically had to go to the highest buffer to do anything.
So I went back to Sierra and 2019.5 seems to be working pretty well. Should I try High Sierra? Should I go back to Mojave and troubleshoot and try and fix whatever was going on? Curious if people have gone through this and found an OS that feels the most stable/speedy. (I know "feels" is pretty subjective but unfortunately that's what I feel like I have to go on with latest PT releases sometimes). Thanks for your help!
(I have a Mac Trash Can with 32gb of RAM, HD | Native, and an Omni)
Old 05-31-2019, 09:09 AM
tetonica's Avatar
tetonica tetonica is offline
Default Re: Which mac OS for PT2019.5??
Originally Posted by Markrosoft View Post
freezing/crashing (with a weird stuck audio loop))
With macOS Mojave I had the same issue (weird stuck audio loop) but performance got better after I disabled multi-threading, so instead of 24 cores my system sees only the real 12 cores of my Mac Pro (trashcan) and Pro Tools seems to behave much better (weird audio loop temp freeze went away) -> https://support.apple.com/en-gb/HT210108
Old 05-31-2019, 09:24 AM
And do you think that causes better performance than leaving the viritual cores and using a previous OS? (Are are you on a new computer and stuck with Mojave??)
I'm only rocking a 3.5 GHz 6-Core Intel Xeon E5....
Old 05-31-2019, 09:29 AM
tetonica's Avatar
With the virtual cores I got the temporary freezes audio-stuck-loop. It wouldn't crash but it would stop everything until the audio-stuck-loop was gone. Without the virtual cores I don't get the freezes audio-stuck-loop anymore (like never). Running a Mac Pro 2013 (trashcan) with 12 cores 2.7 Ghz on macOS Mojave (^_^)
Old 05-31-2019, 09:39 AM
Sorry - I'll restate my question: Do you think your current setup is better than running a previous OS?
Old 05-31-2019, 09:53 AM
tetonica's Avatar
Ah - if your performance is better with a previous OS then stay with what works for you Guess I was explaining my personal experience since I was already running Mojave and I also experienced the sound-freeze-loop thingy (mostly when tracking) and disabling hyper-threading fixed it. But if you want to keep all your virtual-cores it may be better to stay with previous macOS
Old 05-31-2019, 01:29 PM
Sugarnutz Sugarnutz is offline
Those real cores with hypertheading disabled are twice as powerful as the pseudo cores you get with hypertheading on. Can’t get something fer’ nothing!
HD Native Thunderbolt
HD6 Accel in Magma PE6R4 Expansion Chassis
PT HD 10, 11, 12, Ultimate 2018, 2019
Cubase 9.5 Pro
Vienna Ensemble Pro 7
Icon D-Command
HD Omni
192 Analog I/O 8 in/8 out/Digtal I/O
192 Analog I/O 8 in/Digital I/O
Two 192 Digital I/O
Apogee Rosetta 800, AD16X & DA16X (All wth X-HD cards)
Antelope Zen Studio+ Thunderbolt
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.3
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
MacOS 10.14.5 Mojave
GIGABYTE GA-Z97X-UD7 TH
Intel Core i7-4790K 4.4 GHz
32 GB of DDR3 1600
EVGA GTX 760 Video Card
OS X 10.13.6 High Sierra & Win 7 Pro 64 bit
Dynaudio BM5 Mk III
B&W 604 s2
800W 15" Ported Subs
McIntosh MC-7106 Bridged ~ B&W
Hafler P7000 "Diablo" ~ Subs
Old 05-31-2019, 01:51 PM
JFreak JFreak is online now
Default Re: Which mac OS for PT 2019.5?
Usually all sotware, OS especially, gets bloated over the years so in theory the most efficient OS is the oldest your hardware and software can support together.
This is especially true with Mojave as you really need to pay attention to GPU requirements before you decide it's a good idea.
Of course, there are certain benefits when app such as PT 2019.5 has clearly been finalised with Mojave in mind but your hardware needs to be up for it.
Old 05-31-2019, 02:06 PM
I have a 2015 rMBP i7/16Gb/512Gb flash running high Sierra and PT. 2019.5, it’s Okay, better than 2018.12. Now yesterday I had a day to screw around, so I took my new PC, i9 9900K/64Gb/18Tb and out of that 18Tb of storage I had a basically un-used 1Tb NMVe drive. I got a wild hair to put MacOS Mojave on it. It was a mild PITA, but nothing like it was before 10.14.5 came out.
This thing screams with Pro Tools 2019.5 even using the USB 2.0 connection on an Antelope Zen Studio+ at 32 buffer (I have had “Zero” success with Antelope Thunderbolt with off-label usage of OSX). I have my HD Native Thunderbolt hooked up and it appears to be working fine, but my Omni is in a rack in another room and I didn’t want to deal with it. Anyhow I loaded a 20 track session I had on a thumb drive, mostly stereo tracks and a few plugins. I had to squint to see the CPU usage, average 1%, spiking to 2%, virtually nothing on the 16 individual threads. I do music mostly and a little MIDI stuff that usually ends up on Cubase Pro 9.5 ‘cause my friend in Nashville uses Cubase. This thing is by far the last rig I thing I’ll ever need (but you know what “Phallic Envy” is like when it comes to this stuff).
I’ve been downloading/loading it with plugins and VI sample libraries since last night. If the record latencies turn out to be good using HD Native Thundbolt and it holds up to being pounded by my plugin/VI assault I’m gonna delete Win 10 Pro off this machine and covert the whole 18Tb of storage to APFS. I’ve had some security issues with Microsoft/Google products lately that even though I’ve been a “Microsoft Guy” for over 30+ years, I see nothing but Apple in my future now.
I think Mojave is the thing going forward with Pro Tools and if they can actually improve this with future updates we’re gonna be golden. Does this answer your question?
Cubase 9.5 Pro
Icon D-Command
HD Omni
Two 192 Digital I/O
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
32 GB of DDR3 1600
Dynaudio BM5 Mk III
B&W 604 s2
Old 06-01-2019, 05:53 AM
How did you 'update' to Mojave? The Apple Way aka in-situ where you install over the top of an existing OSX or the Right Way and do a clean install? I'm guessing you did it the Apple Way and no matter the OSX versions involved can lead to all kinds of weirdness.
2019 Gui Lag manfromspace Pro Tools 2019 7 06-20-2019 02:59 AM
2019.8 amagras Pro Tools 2019 89 06-10-2019 01:40 AM
SO4.5 Wow vs. PT 2019.5 Justin1524 General Discussion 2 05-22-2019 02:45 AM
Looks like at least 2019 before new Mac Pro K Roche Pro Tools HDX & HD Native Systems (Mac) 3 04-19-2018 07:44 AM
