Re: Eleven Rack Digi002 Rack Set Up
That's great. Can I just use normal red and white audio RCA cables? Or are there specific SPDIF cables I need to buy?
you can get good ones any where, even Walmart or Radio Shack http://www.tech-faq.com/spdif.html http://en.wikipedia.org/wiki/S/PDIF http://www.music123.com/m123/Accesso...0000000602.sku http://www.walmart.com/ip/Monster-Ca...Cable/11081079 http://www.sweetwater.com/store/detail/DRA501/ all those should work. remember you need 2 of them. EDIT: I did a test using just a standard RCA cable (thin cables, red, white heads) http://images2.monoprice.com/product...ages/20081.jpg and yes they will work. I do not suggest it though. They would be ok in a pinch. Just note if you go this route, and plug the White head to the white input of the 002 (IN) then the other end of the White would plug into the RED input of the Eleven Rack (OUT) and vice versa. This is self explanatory of course, the OUT of the 11R goes to the IN of the 002, and the Out of the 002 connects to the IN of the 11R. Also the standard Yellow RCA cable for Video should be 75 ohm, which is the same as Digital Coaxial/SPDIF, They call them "digital" coax, but the SPDIF interface specification says you only need a 75 Ohm RCA terminated coaxial cable to transmit digital coax audio. Another name for a "75 Ohm RCA terminated coaxial cable" is "video cable", something that is given for free with almost every video component sold. Yellow RCA is 75 Ohm video (and digital coax audio.) Best bet is to get 2 Digital Coaxial/SPDIF cables, they are cheap enough.
You all are going to be very dissapointed, like I was. There is no simple way to hook ER with 00X
http://duc.digidesign.com/showthread.php?t=267088 |
If you are referring to "seeing" the 11R inputs in Pro Tools with it hooked up to another host, then no you wont see that, just like any other outboard processor.
@Benoni
I'm happy if it works for you. Would you be so kind and post your setup, please? The ideea is to hook it so that you can record the guitar and change the sound via ER later. And to use the 003 like your main interface, and ER only for guitar. Everybody on the thread mention above agreed that is a difficult task... But I will be very happy if you found a simple way around!!! Best regards. |
You are talking about Re-Amping now. And that has also been covered. Quote:
@benoni & avid
Not sure we want the same thing. I am talking about a simple thing like this: * I have a session, where I use the ER to record a guitar track. * I'm done with recording, but not satisfied with the guitar tone... * So I want to change it fra ER. * I would like to do that using 002/003 (wich is a better interface...), and I would like to hear what I'm working with, via the monitors, because if I change to ER, I have to switch the cables fram 002/003 to ER. * Simple workflow. |
You can do this via the spidf digital i/o with no loss of quality. I don't have my Eleven rack anymore, but if I remember correctly, it goes like this:
Assuming you've recorded a dry track in addition to your effected track, you want to send the dry track through 11R with a different amp, etc. On the dry track, you go to the inserts, and instead of inserting a plugin, you choose "i/o", and choose the spidf. This routes the signal through the 11R and back in. It's using the 11R as an effects processor, just like you might use a hardware reverb unit, etc. You can try different amps, and when you know what you like, bus that audio track to another audio track to record it. |
Goga...
What I think you're talking about isn't as simply done with the 11R hardware device as it is with the 11 plug-in. Your best bet is to do exactly what has been explained here and then re-amp to the 11R, recording another audio track - either as a new take on the same track or another track. You are correct, you cannot record a dry signal and apply 11R to it as an insert, as it is a completely different device than a plug-in. I am running the exact setup decribed in this thread and, albeit there is a bit of a work-around compared to the plug-in, I find it perfectly functional and am very happy with it. Best suggestion for switching your monitors between the two would be to use a patch bay with your monitors always connected to it and then you'd switch the inputs to whatever device you are using. I'm contemplating doing this, myself. Most important thing here is: DO NOT think of 11R as a plug-in. It's not. It's external hardware with some awesome interface options. Think this through and use it as such and I'm 100% certain you will be nothing close to disappointed with the 11R. |
Re: Eleven Rack Digi003 Rack Set Up
So it seems there are various ways to make these things talk to one another. Wouldn't it be cool if AVID were to provide a document that at least shows the different ways their own devices could connect to each other?-- Like a matrix that you enter your devices and it generates optional setups you could use based on your needs. I'm trying to use an 003, an Eventide 3000, an ER, and two Tannoy 601a monitors. I have sound alright but I don't have playback from Protools yet. I think it's because I have the TNY's coming out of the ER instead of the 003 because I wanted to use the XLRs. More cable swapping is forthcoming. I have faith it will work out, with all of your help of course!
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Pro tools keeps using Eleven rack instead of digi002.. among other weird probs.. | awritersparadise | Eleven Rack | 3 | 07-21-2012 02:11 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Advice for Foot Controller and Rack/Case for Eleven Rack? | udamann88 | Eleven Rack | 19 | 03-08-2011 06:24 PM |
THE FOOT CONTROLLER for the Eleven Rack and any other rack modeler for that matter.. | vkaxeman | Eleven Rack | 3 | 01-19-2011 04:13 AM |
