Old 12-17-2013, 05:36 AM
bbbirchey bbbirchey is offline
Default 5.1 track order
trying to open new session using ITU track order - but the track in the edit window shows Film track order
Old 12-17-2013, 06:53 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 5.1 track order
Have you checked your I/O setup window? And if you have the tracks in wrong order you can always create mono tracks and move the 5.1 into those, then move them into proper order and move back.
Janne
Old 12-17-2013, 07:01 AM
Thanks ! I just have to do a dolby-E encode in ITU track order. I normally work in Film order. In session I/O it definitely says track order is ITU but visually it still looks like Film order and even if I pull in an interleaved or multimono mix the order still appears L C R Ls Rs LFE. ( protools 10)
Old 12-17-2013, 10:29 AM
Matts Matts is offline
What you see is the FILM order, that Pro Tools uses internally.
If you Record To Disk using a bus that is setup in ITU order, your recording should be fine (ITU).
And you can always use this: http://www.sounddevices.com/products/waveagent/ if you need to verify the order - or change it.
Hope this helps.
-matts
Old 12-17-2013, 11:19 AM
Thank you matt! That's crystal.
Cheers! day
bounced to QT track order vudoo Post - Surround - Video 0 11-27-2013 11:00 PM
Order region list in the order the regions are on a track Wesselink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-30-2009 06:53 PM
Mix and Edit: different track order? max cooper Tips & Tricks 4 11-02-2004 03:47 PM
Master track plugin order Greene Pro Tools TDM Systems (Mac) 2 07-13-2003 09:43 PM
switch order of inserts in a track Viper Tips & Tricks 6 02-25-2000 08:57 AM
