Old 09-03-2005, 03:35 AM
Jano Vesta Jano Vesta is offline
Default Markers (memory locations) (ProTool HD 6.9.2)
I've just imported tracks from my old session to the bigger new one. Is it possible to import/export memory locations (markers) between sessions? Have I rewrite every one by hand? I'd be grateful for any advice.
Old 09-03-2005, 01:01 PM
Vaporhead Vaporhead is offline
Default Re: Markers (memory locations) (ProTool HD 6.9.2)
Export a midi file from your old session and import it into your new session. The markers will come along with the midi.
Old 09-06-2005, 03:24 AM
Than you. I've checked it, but unfortunately it doesn't work.
Regards
Jano
Old 09-06-2005, 04:20 AM
Andre Knecht Andre Knecht is offline
Jano - the advice given by Vaporhead is indeed correct.
What exactly do you mean when you say “I’ve checked it”?
What exactly do you mean when you say “it doesn’t work”?
What exactly did you do?
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 09-06-2005, 04:44 AM
I've said “I’ve checked it” and “it doesn’t work” making comments to VAPORHEAD advice :
"Export a midi file from your old session and import it into your new session. The markers will come along with the midi".
It doesn't work because importing Midi Track we can import only Midi events, tempo and meter, NOT MARKERS.
Regards
Jano
Old 09-06-2005, 08:01 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
I can confirm it does actually work. BUT you must have actual MIDI data in a track in the export. Try to choose 'import tempo from MIDI file.
The final thing to try is make a copy of the session with all markers and delete all the tracks. Then use import session data and import all the tracks from the new session.
ainslie
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Markers (memory locations) NGokhool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-09-2014 07:17 PM
Import EDL as Markers/Memory Locations BigBangPost Post - Surround - Video 2 09-08-2010 09:33 AM
Memory Locations/Markers GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 10-20-2008 08:56 PM
Memory Locations / Markers not showing up in PT6.4 TWoZ Post - Surround - Video 1 10-19-2004 10:07 AM
Markers / Memory Locations not showing up in PT6.4 TWoZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2004 10:05 AM
