Old 10-10-2023, 06:54 PM
Sparky1 Sparky1 is offline
Default Presonus Faderport
Hello.
As I start to get more and more involved in learning the mixing process - I’m wanting to use as actual fader to write automation instead of a mouse…
I checked out the options from Avid - but they are a bit more than I can justify right now.
I did come across the Presonus Faderport V2 (single fader). This seems like a reasonable option for me at this time in terms of functionality and cost.
Anyone use this and thoughts on its integration with Pro Tools?
Thanks
Sparky
Pro Tools 2023.12.0
Avid Carbon
Ventura 13.4.1
Old 10-10-2023, 07:13 PM
sw rec sw rec is offline
Default Re: Presonus Faderport
I’m running the ORIGINAL version on PT 2023.6 (on MAC VENTURA, which isn’t supported, but I plugged it in and went to work!) I mainly have mine because when I do a “punch-in,” I have an actual button to punch. (Or mash, if you’re from the South.) It’s worked splendidly on Windows, works great on MAC. Go for it.
Old 10-10-2023, 07:24 PM
smurfyou smurfyou is offline
Haha yes we happily mash buttons here
From what I've seen the Faderport V2 is improved over the original. "Integration" with PT is still very limited as it is with any HUI controller. But it works for fader and basic controls.
~Will
Old 10-10-2023, 07:47 PM
Thanks for your insights sw rec and smurfyou
While checking out some user videos just now - came across a couple of people comparing the Fader Port V2 to the Behringer X-Touch One
Any thoughts on the Behringer?
Thanks
Sparky
Pro Tools 2023.12.0
Avid Carbon
Ventura 13.4.1
Old 10-10-2023, 08:16 PM
My experience with Behringer is, lower price point at entry, but prone to unexplained failures at the worst possible moment. I’d stick with the Presonus. Infinitely more reliable.
Old 10-10-2023, 09:47 PM
ZZR1100 ZZR1100 is offline
I've had a FP1 (pretty good) and a FP2 (quite a lot better!) with Pro Tools. You don't get 100% of the features with PT but it works great for me. The buttons feel good - just make sure you've set it to HUI output for PT (see the manual - takes about 15 seconds.)
Mac Studio M1 Max 32gb
Pro Tools 2023.9
Ventura 13.6.6
Focusrite Clarett+ 8Pre
Old 10-11-2023, 07:28 AM
Never used the Behringer. On sight it looks very decent but they have that reputation mentioned above.
~Will
Old 10-11-2023, 08:11 AM
midnightrambler midnightrambler is offline
I have an FP2 that’s sitting in a box unused and unloved. There was something about it that I found annoying but I can’t remember what it was now, I think it might have been frustration at getting it to choose the correct channel. I’ll set it up again and see if I can remember what the problem was.
Old 10-11-2023, 08:30 AM
daeron80 daeron80 is offline
Was it because automation was disabled on the selected track? That's why I quit using my FP1. When I was just tracking, I'd enable it. But I had to remember to disable it as soon as I started mixing. After a few years, it just wasn't worth that hassle anymore.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-11-2023, 08:53 AM
Yeah… definitely leaning towards the Presonus unit.
Thanks
Sparky
Pro Tools 2023.12.0
Avid Carbon
Ventura 13.4.1
Help w/Presonus Faderport Please!! Vlad Drac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-31-2012 02:37 AM
Presonus Faderport - PT 8.0.3 & Win 7 fiddlecat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-07-2010 03:15 PM
Anybody using the PreSonus FaderPort? Fernand Bos Tips & Tricks 4 10-28-2006 04:13 PM
PreSonus FaderPort editdoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-21-2006 03:21 PM
Presonus Faderport G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-06-2006 08:54 PM
