Old 10-03-2022, 07:02 AM
tomguest.tv tomguest.tv is offline
Default The Aux I/O device has disappeared from the system and will be disabled
anyone else getting this issue? has happened twice today and I have needed to re active in the Audio I/O page... maybe too soon to retire nexus!
Old 10-03-2022, 07:16 AM
Default Re: The Aux I/O device has disappeared from the system and will be disabled
my setup has started doing it every ten minutes or so now I've posted about it
Old 10-03-2022, 07:34 AM
its2loud its2loud is offline
How are you using the Aux IO? Post a pic of your IO setup and you provide zero system info
Old 10-10-2022, 05:46 PM
feakerboo feakerboo is offline
I'm having the same issue here.
Systems setup:
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
OS 12.6
Single card HDX with Sonnet Chassis.
I have 6 custom maps that are showing up just fine and I also have the Dolby bridge in there. It very much seems like a sync issue. There's a lot of pops and clicks and after a while I get
"The Aux I/O device has disappeared from the system and will be disabled"
-for every Aux io interface that I have in my io setup. Then I have to restart and redo all the io setup work again.
It seams like using Aux io with source connect might possibly be the issue. When I was using Nexus I NEVER had an issue like this.
Brad e
Partial Credits
Old 10-11-2022, 07:08 AM
I am having a similar issue. I have Aux IO outputs feeding the Aja IO4K to feed audio to my TV, another output going direct HDMI to my TV for extended desktop, and PTAB 2a & 2B to feed Zoom/Google Meet.
I have gotten the same message a number of times. I feel like when I do a Zoom or Google Meet meeting while Pro Tools has a session open, but I'm not using the PTAB feeds, just using DVS in and out of Zoom/Meet, this is when it happens the most, but that is just speculation.
Mac Studio Max 64GB 2TB
macOS 12.5.1
Pro Tools Ultimate 2022.9
HDX1 in Sonnet Echo III-D
MTRX Studio + Sync HD
DVS feeding system audio into DADman
Aja IO4K
Aja Gen10
3 x S1 + Dock
EuCon 2022.9
Scott Gatteño
Old 10-28-2022, 01:07 AM
has anyone figured out what this might be?
ta
Old 10-28-2022, 07:27 AM
BiggiT's Avatar
BiggiT BiggiT is offline
Old 11-15-2022, 07:25 AM
O.v O.v is offline
Same issue here.
ProTool looses Aux i/o 3-4 times in a 1 hour zoom call.
Old 01-18-2023, 03:07 PM
weezul weezul is offline
Have started seeing this too, but not when I'm actually using it. I only use it for perhaps an hour a week and it's been okay. But for instance if i leave PT open for a bit, sometimes, even just the screensaver activating will bring this up.
M1 MacBook Pro, 2022.12 rosetta
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 01-18-2023, 04:21 PM
The Weed's Avatar
The Weed The Weed is offline
Have a look at www.gingeraudio.com. They have a free routing app and a reasonably priced routing app for Mac. Supposed to be working on a Windows version.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Avid CoreAudio Device in System Preferences Daryl Hughes macOS 4 01-01-2014 10:41 AM
Mbox 3 not sticking as system output device darwiniandude macOS 1 12-15-2010 01:27 PM
I disabled Mbox in device manager - How do I enable again? stev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-27-2008 02:32 PM
master clock device for mix system? digidesigner Pro Tools TDM Systems (Mac) 2 01-30-2008 01:53 AM
Digi001 as preferential in\out multimedia system device? salvo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2000 01:40 AM
