No playback sound in Pro Tools Express
I recently installed Pro Tools Express for use with a Fast Track Solo interface on a macbook pro OS 10.8.4. I seem to have installed the software correctly, and am able to record through the interface with my mic hooked up (seeing the appropriate levels and tracking, etc), but I can't get sound during playback. I've poked around in my I/O setup and changed the output via my computer's System Preferences -> Sound -> Output. Nothing seems to work, although everything else in the setup appears to be functional. I imagine it's an easy setting fix but I'm a noob and could use a little help. Thanks in advance.
Re: No playback sound in Pro Tools Express
Welcome to the forum. When you said "poked around" in the i/o settings did you set all choices to default and restarted as that seems to help out for quite a few members here. Best Christopher
Changing outputs in the system settings don't affect PT.
Go to Setup -> Playback Engine and make sure, your interface is selected.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
what worked for me is to go to the IO settings and press Default on every screen
(and then obvs connect headphones to the Solo unit) I think the problem for me was that this lappy had been used on so many different systems and hardware configs that it had ended up with a legacy of old IO settings
www.piersgibbon.com www.soundcloud.com/piersgibbon VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins) Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive Backup:15 inch early 2008 MBP, OSX 10.10.2 (+Windows 7 PC running Audio TX isdn and tbu codec) Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4 |
Problem with Pro Tools Express receiving sound from my M-Track Plus Audio Interface | milobehr | Third Party Interfaces | 4 | 01-02-2014 06:24 AM |
Pro Tools Express with M-Track Plus and ASIO 4all -can't get sound | Redbirdi | Windows | 1 | 07-16-2013 06:05 PM |
Getting signal from controller but no sound or playback in Pro tools LE 7 | ach | Pro Tools Express on Mac OS X | 1 | 02-22-2013 01:55 AM |
No Playback sound - Pro Tools SE | lcreed | Pro Tools SE and Essential (Win) | 2 | 01-17-2013 12:59 PM |
No Sound Playback from Pro Tools LE | kenobi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-02-2007 05:38 PM |
